hector6173
- Joined
- Sep 21, 2010
- Posts
- 3
- Reaction score
- 0
Does anybody know if putting v6 springs on my gt give a softer ride or will this just screw the suspension. Not a drag racer and don't corner @ 75mph.
To me, stock is pretty danged soft. It probably helps a little bit I am coming from a GTi with Bilstein coils set on the stiffest setting. Also, I've ridden in some other stock GTs that have felt a lot harsher than mine.
I spoke with Sam Strano and was told that after swapping to whatever non stock springs you choose the shocks need to be upgraded as well or the ride will suffer. Even though I went with the CJ springs which are not a whole lot different from stock he told me the reason I has not felt much of ride difference was my shocks only had 3K on them and were new enough to not be affected.
I went with the Koni SRT's based on his recommendation which are a good mix of street/strip performance.
Get a Taurus.
