Installing a paxton novi 2200.
DSargent09
Get iT!
I havent noticed any kind of smell.... But I run an o/r x so i catch that smell from time to time.
gremlinsteve
What ever route you take do not half ass it
These cars are animals with boost.
Ask me what stock p zero tires on my Laguna do when the rpm
Increases and boost come in to the party.
Things happened very quick. Cars make hard turned with no input kin concrete
Walls and curbs. I know this because my 862 hp beats is hurt
Every chromoly suspension part on the car is new. It's now all broken
Litteraly in half
I'm out for now
frank s
at Play
Paradise
Litteraly in half
I'm out for now
At least you're getting the medication you need.
Blazer707@TBR
Nor Cal
Litteraly in half
I'm out for now
Sorry for your lose, that's exactly why I only beat on my car at the track with my slicks and skinnies on.
beefcake
Forced Induction Specialist
Bethel, Ohio
Litteraly in half
I'm out for now
Damn brother. Take care of yourself
Blazer707@TBR
Nor Cal
Just wanted to update this thread, Been driving on my Paxton car for about a week now and it is a blast to drive. Pulls harder then I thought it would and is fun on the street.
Bullett
Pwnisher
Mission, TX
Alright guys, so I'm pretty happy woth my current setup and has ran stout numbers. It's gone 10.9@130 with orx and the paxton kit in cold weather with boost nearing 12psi on a 3.6 pulley. I recently installed the torque booster and went 11.1 at 130 with bad weather and 9 psi. I am up in the air about adding a boss intake. I'm still running the stock gears/converter as well. I get feedback saying to stick with the stocker then others telling me to do it. What do y'all think? In the future a 3c 245mm converter will be going in and long tubes as well.
onebadgsx
Houston, TX
Stock gears are fine. I went 11.0 on stock convertor and 10.37 with a 3c so convertor is well worth it
D
Deleted member 162826
Guest
How are you guys connecting the Paxton air tube to the airade box? I got the 4x4 tube, but what coupler are you using to connect that to the box?
D
Guest
I'm balls deep in my Paxton build, currently installing my billet oil pump gears. What's the best way to remove the small belt from the crank pulley?
