Installing a paxton novi 2200.
gizmo5
Italian between my legs
From left to right 4321 brisk plugs in car with Paxton.
doesnt look as bad as I thought it would be with all that smoke. regardless, shes hurt. dont make it worse. Time for a shortblock.:beer:
bhowardb
YellowBlaze
DSargent09
Get iT!
I would wait until you got it apart before I ordered a rotating assembly. Not to be a Debbie downer but there could be a hair line crack in the typical #8 cylinder spot.
DSargent09
Get iT!
Yes sir, again I do not want to jynx it and I don't think you were making enough power to do that, but you truly never know until you get it apart.
stang8psi
Slower,Lower Delaware
block I bet will be fine, and I bet you will be able to get away with a std bore piston, Your head will be fine also, if it was hurt than you would know it (piston to valve contct or knocking will occur).
bhowardb
YellowBlaze
I would agree, but I'm thinking that if I have the heads of and cams out I will do the blower cams. If I'm going to go through all that I might as well have someone go through the heads.
Wnt2gofst
Banned
Columbus GA
What's the cheapest way to get forged internals? Boss assembly?
Nope..just build. For basically same orice can build stronger. Cheapest I found boss short block is about 2900. Thrn you have to install
I was told about 6500-7000 for parts labor to do built short block.
from my S4 in your sisters bed
bhowardb
YellowBlaze
Wow
That seems a bit expensive on the labor side of things. Is that labor of them pulling motor, building and re-installing?
I was going to pull the motor, disassemble, have a machine shop prep block and balance assembly.
Paul.
Phoenix
What about just buying an Aluminator then? It's only a little more and comes complete. Labor is just simply pulling/reinstalling the motor and all the other crap.
Paul.
