bhowardb
YellowBlaze
- Joined
- May 2, 2011
- Posts
- 151
- Reaction score
- 1
Plugs 5-6-7-8
Left to right 5678
Left to right 5678
From left to right 4321 brisk plugs in car with Paxton.
doesnt look as bad as I thought it would be with all that smoke. regardless, shes hurt. dont make it worse. Time for a shortblock.![]()
Its your #8 ring and I bet the piston is cracked or missing a piece
Look at 5678
We gonna find out. It coming apart. Half the blower kit is off now and I'll be pulling the motor in the next few weeks.
You tree'd me on the post, lol. And damn, yup, piston is missing pieces. Guaranteed.
Yup, time for a rebuild, this time with parts BUILT FOR BOOST!!! GET IT DONE!![]()
Also get rid them brisk plugs
from my S4 in your sisters bed
I would wait until you got it apart before I ordered a rotating assembly. Not to be a Debbie downer but there could be a hair line crack in the typical #8 cylinder spot.
Yes sir, again I do not want to jynx it and I don't think you were making enough power to do that, but you truly never know until you get it apart.
block I bet will be fine, and I bet you will be able to get away with a std bore piston, Your head will be fine also, if it was hurt than you would know it (piston to valve contct or knocking will occur).
What's the cheapest way to get forged internals? Boss assembly?
Nope..just build. For basically same orice can build stronger. Cheapest I found boss short block is about 2900. Thrn you have to install
I was told about 6500-7000 for parts labor to do built short block.
