stang8psi
that's how on other threads I was able to keep my build under 4k with all upgraded parts because I am doing my own labor on my own time plus saving the R&R, and Labor for disassembly and assembly of the motor.
e85...
I can say one zhop wanted al.kst 7k to build a short block with oarts. Tben added almost 5k for labor and tuning. I will not be using them at all.
Anotber shop wanted almost 26k for built long block install/parts/labor/lt's meth.
from my S4 in your sisters bed
They are fucking crazy and ripping people off if that's the case.
I agree. One is a very very well know shop. That deals with ford/gm.
What is this fancy shop you're talking about?
Interesting that you say its livernois, because on another forum they are building peoples short blocks for 1999 and that is including the machine work and the assembly work so where that 8-9k+ price is coming from if they are building the motors for parts 1500 and labor and build for 1999= 3499.00 so you are saying they are charging 5000+ for removal and installation of motor? That is fucking crazy and a rip off no way it should cost that I can see 1500-2000
Livernois does not use sct to build the tune. They just use it as a means to load the file.
Confused about this statements place in thread?
They go above what the average sct tuner does when making a file. They adjust a lot more than the basics.
So do other tuners. Not sure what your point is here. Are you saying the inflated cost of the tune is warranted?
quick question for anybody using any type of breathers on the valve covers instead of pcv valve... what did you do on the passenger side with the pcv valve? did you just put the breather over the valve?
i was under the impression the pcv valve comes out completely but then there is no way to attach the breather to the valve cover. what am i missing with this?
