Intercooler, M90 3v
scottythesparky
Cool thanks for that guys I'll need to see if I need to upgrade the electrics as that new pump will draw more current and ill need to look at the header tank as I think it's good for 10psi...:)
Pentalab
Straight 100% distilled water will extract way more heat vs a 50-50 water-glycol mix. But the trick is, then you also require 1 full container of redline's..."water-wetter" in the loop. Royal purple also makes their version...called 'purple ice'. I believe both versions come with anti rust inhibitors built into them.....so no additional anti corrosion is required. 0% glycol won't work in the fall/winter...so you would have to change the coolant twice a year. (50-50 in fall /winter)
The intercooler extracts the heat...and the grille mounted HE dumps the heat. A 8-12-20 gpm pump will extract heat faster...but you have to be able to dump that extra extracted heat at the same or a faster rate. Otherwise you will just be circulating hot water in a loop.
The OEM HE that comes with the 05-09 Roush M90 blower is on the small side. Steeda / Afco etc, etc make better ones..like dual and even triple core types....with and without fans. A bigger capacity DE-gas container will also help. The oem roush 05-09 bottle is too small. The one on my 2010 M90 is double the size.
If you don't have the 9 bar grille on your car... it comes highly recommended. That alone will increase airflow by at least 70%. It will also eliminate the 2 x 90 deg bends into the CAI. Air is free..so why not use it.
Another approach to reducing under hood temps is the use of ceramic coated LT's. I had installed JBA titanium ceramic coated LT's....and my under hood temps dropped a whole bunch...like 40 deg F. I can touch any of the 8 x primary 1 5/8" tubes within 3 mins of shutting the eng off. B4, the black steeda STB across the top of the blower would burn my fingers. The theory here is...don't generate the heat to begin with. Ceramic coated exhaust systems are dipped...and coated on both the inside and outside. The exhaust is hotter inside the LT's = flows faster. LT's imo were worth it alone...for the increase in TQ from idle to wot. The ones I used had 1 5/8" primary..and 2.5" collector.
Jimbo
crownaviation
http://www.tudyno.com/
Broke dafuk down
Agreed.. cooling is your best bet for now. You lose a TON of power when that poor m90 heats up (which happens fast). We tested one and found a larger pulley slowed the blower down for an initial power loss about 25rwhp) but kept more power in the long run as it did not nuke the IAT and pull power. On one pull we noted it pulled so much timing we lost 80rwhp with the small pulley spinning the crap out of it! Lost way more than we gained when cool.
Upgrading cooling now is a good move as if you decide to build/buy a forged shortblock later for more power. You will still want the better cooling no mater what blower you drop on there.
All been pointed out in thread already.. afco (I do like mine with the fans) and meziere 20gpm pump. Think the part number on the pump is wp136s. It is a FANTASTIC unit and only personally know of ONE failing which meziere quickly replaced. The bosch is a piece of shit pump imo... You WILL need the blue fittings they sell as they are not a standard fitting.... unless you are handy but just not worth rigging something when the fittings are reasonably priced anyway.
Plus,, not sure how your m90 heat exchanger is plumbed but when you do this pump you may need to make a bracket (nice thread with dimensions on here... search for tmcolger thread on that). When installing the meziere I would recommend ensuring the heat exchanger fills from bottom up. The GT500 for whatever stupid reason did this backwards and is a turd of a design.
