issues with saleen 302 stroker!!!!
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Originally Posted by US-1
You have the stroker crank and rods but the pistons are for the standard stroke and connecting rod length. You need to check the piston box and paperwork for the compression distance on the pistons.
Let me guess......horsepower1 on Ebay or did you buy it from Brenspeed?
^^^^ is why him build mah mo-tah :evil:
SAME HERE!!! :highfive:
EagleStroker
N/A Junkie
Memphis, TN
What do you mean balanced??
Your new pistons will have a different weight than your old did, I'm assuming you had the crank balanced to your rod and piston bob weight. I'm not sure if you or a shop is doing this but your shop should know to do this.
Rypper1
Prairieville, LA
oh ok i see...damn i hopefully everything goes right with my car if brenspeend does have them and if i do need the pistons ill just order them for next day air..
That will add a chunk to the price. Where are you located? They got them to me in a couple of days. They are in Pierceton, IN and I am in South Louisiana. Quick shipping without paying extra.
Rypper1
Prairieville, LA
Bought them from Brenspeed. Got here in two or it might have been three days. Free shipping too. Complete kit, rings, locks, pins, and pistons.
onequicktang
Orion, MI
I bought mine from jdm they are 9.8 compression and they were cheaper than brenspeeds 8.5. I have 7 of the 8.5 from brenspeed that I would sell the eighth mine was broke. They only have 118 miles on them so if you can get just one 8.5 I could save you alot of money.
07stangcs
Undecided
Houston,TX
Hmm Never knew people were getting the wrong pistons from horsepower1(foundadeal). I had no problems with the kit they sold me but mine was high compression. I've bought about 6 things from them with a great experience. They sell saleen overstock and a ton of odds and ends. I got my 127300 cams for $350 and a $200 torque wrench for $10 bucks. Can't beat that.
romanGHR
mcallen tx
Problem solved it was just the rod bolts hitting the windage tray everything is fixed and should be up and running by tomorrow hopefully...thanks for yalls imformation
19COBRA93
Ford Racing
Clinton, Ut
LOL, how did that get twisted around to pistons hitting the heads?
And yes, with that stroker (I have the same/similar one) you have to modify the stock windage tray or run an aftermarket one.
kenneth
Louisiana
Not entirely true, I just had 302 rotating assembly from JDM installed in my car, using the stock windage tray with no modifications done to it.
romanGHR
mcallen tx
Everything was fixed with stock tray...we thought it was the pistons bit turned out to be the rods and tray
19COBRA93
Ford Racing
Clinton, Ut
Interesting. Mine is the 3.80 stroke and it definitely doesn't clear the stock windage tray without a little grinding.
