1950StangJump$
- Joined
- Apr 1, 2010
- Posts
- 968
- Reaction score
- 108
Yes. Per the instructions
It does not eliminate the plug. I'm running an SCT aftermarket MAF and I had to use the harness.I'm running th lightning maf, which I believe is a 6 wire. I had to get the adapter harness that is a 4 wire. Does this eliminate that manifold sensor? Should I plug it?
That's what I was saying earlierI think i have figured it out. 2 wires need to be cut from the maf. They are the maf IAT signal wires. These two wires need to be spliced into a connector to the IAT sensor on the intake manifold. Can anyone confirm this theory.
The old method was cutting the MAF sensor off and relocating it to the other side and soldering back into the harness. The two outer wires of the MAF (I believe) on each side of the plug would be soldered to a new connector for that plug.
In the new method, an entire extension about 5 feet long is included with the kit that automatically splits out for the IAT and MAF. So there is no more cutting and splicing.
You were absolutely write. I dont know why I didn't understand what you were saying. Maybe it is my fear of cutting wires. Thanks for everyone's support. Especially since this was thread jacked. Lol
So what IAT sensor do we use. I go to the parts store and the only one they have isn't a threaded sensor. What year and model works for us?
Car is up and running and being tuned. Working on a low boost issue now. I have a 3.5" on the car and only making about up to about 7psi with stock heads and mostly stock exhaust (axlebacks).Did you ever get this all resolved? I had a KB 2.6 setup on mine for a few years, got pics of various things. There was a hard-copy manual, but I think I gave it to the new owner of the setup.
If you need any help, feel free to PM me or post here.
