L&M Throttle Body
blackshelby
These are with out a retune? Just straight bolt on?
It will work on as a bolt on if all stock.
A tune is recommend if no tune is in the car to take full advantage of it.
The stock ford cal will close the TB at wot
The testing we did was with no re-tune.
We tested them on a totally stock setup(which you will gain in the mid range from the TB but not much if any at peak with the stock cal because of what the cal does at wot).
We then did a back to back with the ford cai and tune already installed in the car as a baseline then just added the TB and gained 10rwhp (no re-tune) just a TB swap
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
There's more to a throttle body than peak power numbers. How is "drivability" affected? Does it improve throttle response or the smoothness of revs?
Wnt2gofst
Banned
Columbus GA
Thanksfor the info..I will be doing a complete dyno tune to since adding a few other things as well..
blackshelby
Totally agree.....
Driveability is like stock.
Throttle reponse and smoothness will improve.
Beside peak is hp numbers under the curve which can and will show bigger gains then seen at peak power.
Its all about average HP not just peak power.
Jim Vaccaro
Totally agree.....
Looking foward to more throttle responce ,,all these things add up...
carbd86gt
Lethal Performance
South Florida
I'm sure...
There is no way to gain 2mm just by porting, the blade itself is still only 80mm. There's more than just 2mm worth of diameter that goes into these L&M throttle bodies. All these guys do is airflow, they have a whole bunch of tricks they do to gain more airflow, but also keep the velocity up as well.
Full_Tilt
what...
The stock intake will "close" the throttle body at WOT? That makes no sense.
Tay
La Jolla
Will this work with a JLT CAI and Boss 302 manifold combo no problem? Thanks
Jim Vaccaro
:beerchug2: I'll put you on the list...
I am getting one end of this week or the next...I really don't expect big gains but n/a every little bit helps,,,Supercharged cars should get a bigger gain for sure,,,,
Update,,I will be picking mine up wednesday:thumb2:
vakane
Minister of sinister
Miami
NIce!!!!...
if the alleged 25 pounds of torque are real.... its worth every penny...
that plus my catback + xpipe + CAi and a custom dyno session... should put me closer to my goal of 450 rwhp...
*JZ*
Boynton Beach, Florida
I think it might have been on ModularFords.com, but some shop tested and they picked up around 4 hp on a N/A setup. I personally think it'll be a great upgrade for a FI setup, but for N/A it may not be a great upgrade for the cost.
Jim Vaccaro
The one i found that was 4rwhp was a 4.6 3 valve..I think the 5.0 should do a bit better...
