blackshelby
- Joined
- Jan 16, 2011
- Posts
- 15
- Reaction score
- 0
These are with out a retune? Just straight bolt on?
It will work on as a bolt on if all stock.
A tune is recommend if no tune is in the car to take full advantage of it.
The stock ford cal will close the TB at wot
The testing we did was with no re-tune.
We tested them on a totally stock setup(which you will gain in the mid range from the TB but not much if any at peak with the stock cal because of what the cal does at wot).
We then did a back to back with the ford cai and tune already installed in the car as a baseline then just added the TB and gained 10rwhp (no re-tune) just a TB swap
I'll put you on the list...
