Lets build a 5.0 ...vendors welcome
Nastystang06
Mt. Pleasant, Tx
Ok so my 5.0 engine is smoking badly and has a ton of blowby after 4k miles and a jlt intake, email tune, and exhaust
im not blaming #8 yet but i do know there is ring failure or piston failure somewhere
so here is my plan :)
i have a ton of experience with the 4.6 modulars so im going to rip this badboy apart
my questions are who sells the best kit, or can put me a kit together for forged rods and pistons, and whats the most i can bore incase i have a scarred cylinder
and can someone educate me on the piston squirters and if i should e;liminate these
i want to keep the same compression as stock so i can crank this thing up on the stock tune and break it in for a few thousand miles
after that i will be buying a turbo, i see plenty of cars making over 600 with 11:1 so i dont see why i cant make plenty like that and with a turbo
and i may do a mild port and polish on the heads, but idk if that would work with the stock tune
Dillon Dollar
oklahoma
Call BBR
but if i was you i would just drop the compression a little, if your going to build it do it right so later you can push 700 + and not worry... in the boss i know the squirters are eliminated
Nastystang06
Mt. Pleasant, Tx
Why are the squirters eliminated?
And if I drop the compression would I still be able to fire it up on the stock tune?
I thought maybe the high compression would help me get out of the hole faster since its manual and will be turbo... MAYBE ds1c im very pulled on these two lol
Coyotetivct
The forged piston has more bottom squirt and hits the piston oilers. They are used in the regular Coyote because hyper piston can't take the same amount of heat. Once you start running on the edge with this piston they go very quick.
Now from a windage lose stand point in a built Forged motor I would block them off. Let the gas do its job like it has been doing for years.
I also think from a tuning standpoint you should pull and read every plug. Just because you are getting a good AFR reading doesn't mean every cylinder is happy. After the dyno pull take the plugs out. One degree of timing can case a failure.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Not quite.
The squirters were eliminated due to windage losses above 7,000 RPMs. The BOSS Roadrunner motor has a higher (7,500 RPM) redline, so the squirters were removed and the pistons replaced with forged ones instead.
http://www.mustang50magazine.com/techarticles/m5lp_1108_2011_ford_mustang_302/short_block.html
Coyotetivct
If you read my second sentence I point that out. And YES they do hit!!!
Nastystang06
Mt. Pleasant, Tx
The reason I want to crank it on the stock tune is there is no local synonymous
And reading the plugs wont be a problem
Ans the tune I had was a lund 93 aggressive and yes I ran 93 lol
Never sprayed or even wired it up all the way
COYO TT
Stangless
Annapolis MD
My car was never sprayed it just started smoking one day and slowly got worse
Ah, I saw all the nitrous stuff for sale in the classifieds and figured you got too generous with the spray.
Theres a lot of vendors around here that sell rotating assemblies or shortblocks that will take what you can throw at it on stock compression. BBR has their Jackal and JPC has their RGR, both which I believe have been pushed to over 900whp.
Or, you can just pick up some boss rod and pistons.....
SteveP
Modular Specialist
Boynton Beach, FL
Shoot me a call. I can gladly help and give you some better options on what to do. And in the end if you go with someone else, it's understandable. We have built some serious new motors. We also have just recently built the highest horsepowered coyote motor in the country (dyno results from King of the Street. Videos' and info to come) but I'm more interested in helping you out sir!
561-417-5555
Ivan 5.0
Still learning...
NoVA
Contact Rick @ Livernois; they build some pretty stout motors and def know their sh!t
Nastystang06
Mt. Pleasant, Tx
561-417-5555
I work 7-7 Days so calling is hard, anyway you could email me some options with prices?
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
I would say soo...Better just get to looking at the High HP coyotes and see what there combos are and maybe send them a few ?'s you might have!@
Nastystang06
Mt. Pleasant, Tx
Hell I may just build my own turbo kit, the hellion kit would be super easy to replicate except I could use the fuel system and turbo if my choice
I dunno if im crazy about there oil return though, it uses a scavenge pump and goes through the passenger valve cover lol
But on the other hand I love the simplicity of the procharger I just dunno if it will be as fast as a turbo
SteveP
Modular Specialist
Boynton Beach, FL
no. it goes to the driver side valve cover. The kit is perfect in the design and works. Like I've stated, highest hp built using the basic hellion system for the 2011. just upgraded turbo
