Lets build a 5.0 ...vendors welcome
CPRsm
I would not copy the Hellion kit. Ask for a full pull dyno sheet up to 7k from any of his vendors. I may become a sponsor here in a bit to shed some light on things. There's a bunch of good marketing going on right now with these engines and supporting parts. It's a quick grab for money going on and I hate seeing people getting fucked
SteveP
Modular Specialist
Boynton Beach, FL
Hellion designed at system that works well. I will glady post our record breaking dyno graph making 953rwhp once we get it from Holley. I don't see why everyone wants to take these to redline when they make peak power at 65-6700rpms.
Turbos make more low end power than any other combination. They can make peak boost at a lower rpm, so they make more low end power easily. Superchargers make more power the faster you spin them, so they make peak boost at high rpm, therefore, on dynos and on track, they make peak power at one point at high rpm.
If you have two equal hp combinations, one turbo, one blower, both making 600 hp, the turbo car will be faster because it has more average power. If you shift a blower at 7k, where it makes 600 hp, it falls to say 4500 on the shift, where it is only making say 450 hp, (because the boost is lower at 4500), it has to run up through the powerband to reach peak power again.
On a turbo car, peak power is very broad, so say it makes 600 hp between 4500 and say 6500. You shift at 6500, it drops to 4500, which is at peak power and big torque, it pulls at the bottom of the gear and runs everywhere, not just at the top of the gear.
In my experience turbo cars do not show the same on a dyno as a supercharged or N/A cars for a few reasons....
1. Dynos cannot load the engine compared to being on the street. Even with loaded dynos, the load changes during the pull. The more load, the more heat, heat drives turbos and makes boost, (turbo speed falls when load deminishes). Supercharged cars are connected to the crankshaft, so they have a fixed speed which increases with engine speed regardless of load.
2. A supercharger is at peak speed at the top of the pull, which shows peak power usually at that point. (similar to a high revving N/A setup.) Turbocharged cars make peak boost early, and because of load reasons can lose boost at the end of the pull, (unless it is a over- turbocharged engine--a much larger turbo being used that is not needed).
The 2011 GT is a high rpm engine because when naturally aspirated, the only way to get more air into the engine is to turn more rpm, which draws in more air, (when not feeding it with a turbo or blower). When a turbo is added, there is no reason to spin the engine as hard, because now the air is being forced in at a lower rpm. (lower rpm engines last longer as well, safer is better in street cars IMO)
Bottom line is that the key is to operate any engine, supercharged or turbocharged, is in its peak efficiency. Whether its low or high. The vehicle will go faster as long as its running there. If its N/A or supercharged, turn it high, if its turbocharged, keeping it lower will be faster.
We see outlaw turbo cars operating lower and lower rpm and going faster and faster. Those engines are able to turn 10 k if you wanted, but they are keeping them in lower rpm bands for power reasons.
As far as the manifold goes i do not know if would help or not yet on this application. My guess would be yes, but only minimally.
Hope this helps a little bit.
Nastystang06
Mt. Pleasant, Tx
Are you saying that pricing is a little over the top right now?
I don't have to copy any kit, I just need a good spot to mount it and i can make it work
I have the tools and equipment needed to do the hotside no problem
CPRsm
That's a whole lotta bull shit lol.
A blown car should maintain a similar dyno graph to it's NA partner. I'm not saying it will make power to 7k. BUt peaks should relatively be in the same spot. The waves of pulses aren't going to change timing in relation to the intake valve because you added a blower. So if it's the same cams.......
CPRsm
No, I mean if you copy it you will copy inherent problems into your kit. The pricing isn't going to change. What I mean is the rush to get stuff to the market to grab the money from people itching to modify rather than wait for problems to be figured out. These engines are the SHIT. But it's throwing wrenches into equations, but people are forging forward to be the first to release.
Dillon Dollar
oklahoma
Shoot me a call. I can gladly help and give you some better options on what to do. And in the end if you go with someone else, it's understandable. We have built some serious new motors. We also have just recently built the highest horsepowered coyote motor in the country (dyno results from King of the Street. Videos' and info to come) but I'm more interested in helping you out sir!
561-417-5555
X10000000000
Bbr has amazing customer service and have helped me before I was even a customer... Their parts and tunes simply make power and outperdorm
Nastystang06
Mt. Pleasant, Tx
I would like to place it where Fastlane put theres, what problems have been found with the hellion?
SteveP
Modular Specialist
Boynton Beach, FL
they do change. Air is being pushed(boost) not sucked(NA) pass the intake valves.
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
CPRsm
There is still positive PRESSURE behind the intake valve on a NA engine when it shuts. This is why engine make more HP as rpm's go up. The air is backing up behind the intake valve harder and creating more pressure behind the valve as rpm goes up. If all a NA engine did was suck, it would make the same power at all rpm like an electric motors. But it doesn't, and that's because the cams change the intake pulses. You manipulate them with intake runner lengths. But actual changes come with cam changes.
If what you say is true why the the hellion kit nose the hell over at 15 psi when it maintained the same power band at lower psi ? The intake pulses are changing with psi ? Don't think so.
Nastystang, can't tell you the problem. there is someone I know knows though. But it would spoil my kits advantage. I'm tearing one into ON3 on the corral with theirs. That ones is going to be fun to watch.
SteveP
Modular Specialist
Boynton Beach, FL
bro, we have has 0 issues with the hellion system and the one on our 2011 KOTS car just made the highest horsepower on a coyote motor in the country. It was up against KB, Whipples, vortechs and prochargers.
This is all i'm trying to say. Not comparing it are starting issues. Their systems work. With the type of piping (bassani), and bends, thus allowing a great flow.
remember too, this is 2011+ we are talking about
SteveP
Modular Specialist
Boynton Beach, FL
then explain how we were able to make big power over all other blowers? Hell, call Hellion if you are concerned about this. 1-505-873-4670
Last thing i'm going to say about this because we are jacking his thread is if you do not like hellion, then don't run it. easy as that. We go off what we see time and time again. And they work!
so if you want to really talk more about this, feel free to again call or PM me.
thanks
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
thanks
I don't run it just get tired of you saying stuff that is far from the truth...First off a perfect turbo kit is unheard of.
2nd of all Evo says there making 1000++ RWHP.....Yet you guys have the highest HP coyote IN THE COUNTRY???....
:omfg:
