Line locks
07 Boss
Sin City
I did a two solenoid unit. Personal preference. It was the way I was taught before you could buy a kit. Install was simple and minimal bleeding of the brakes because you install them in the wheel wells. It also lets you upgrade the brake lines to braided if you haven't done that yet.
Driver's side. I think I drilled 1 hole to mount it right where the hard line from the booster connects with the stock flexible brake line. Then just attach the steel line to the caliper and bleed. I wired the button to my shifter handle.
I think the kit was from SLP.
RocketcarX
95% of my weight is fuel
Colorado
I have the Holley kit that uses one solenoid at the master cylinder. No issues here, you just have to take the time to make sure the brakes are "set" or sometimes it want's to push through the brakes, also hit the tires hard enough to break them loose quickly.
My car has some pretty extreme rear traction so these things may not matter to a guy on regular street tires with a less aggressive suspension.
