m340hv pump, same gears as oem?
Pennsylvania
Hey lads, doing a whole timing job on the motor now, as well as new lash adjusters and roller followers, i have a set of new billet gears coming in from boundry , anyone knows if m340hv pump from melling shares same gears with oem pump?
PS.
Post is comming soon on why you have to do research on the shop 3 times before letting them do something with the engine, and how error on the install almost destroyed a 10k miles motor :(
whitmanink
denver pa
yes it is the same gears, ,, the hardend gears alone cost something upwards of about $340,and the hv and oem,ones have the "standard " softer gears in them,, the HV is obviously high volume output. but they are the same geears
JC SSP
FL
Not tasking you, but if you could do a step-by-step write up this process it would be beneficial to many of us...
Thanks in advance.
Pennsylvania
****UPDATE****
Talked to boundary and Melling, THEY ARE NOT THE SAME GEARS, m340hv gears are thicker then oem pump and billet gears designed for oem pump will not work there, you are asking for trouble if you do so, boundary makes custom make to order set
whitmanink
denver pa
i must not have been clear on what i ment by the same gear,, its the same pitch and tooth , i have the hv pump and it has the standard soft gears in them . and not sure why you would put $300 gear's in a standard oil pump?so i would never would try to put the hardend gears in the standard pump.
