2012 manual with 3.73's
BMR upper and lower arms with relocation brackets (made a mistake and used the lower hole)
BMR adjustable pan hard bar
The rest of the suspension is stock but I was thinking of going with the tokico D specs with steeda ultra lights and steeda mounts.
Stock tires (P Zeros), psi ranged from 36 to 28.
The car is for the most part stock with the only other mods an axle back exhaust and Barton shifter.
I can't hook up at all. best 60' was 2.2x with a 13.2 at 108. I need help, seriously, I'm here because I'm looking for answers. Please PM me or offer some tips.
Yes, I know I need some driver mods but seriously I don't think a pro could have cut under a 2.0 the way the car was set up that day. It sucked because the air was not bad maybe 0 or a slight negative. I have put the arms in the top hole, but now I need some tire and suspension advice.
I would like to also auto x the car and it's my DD so I can't set it up for a hard core drag car but would like to make this thing hook up on street tires as well as have a dedicated set of rears for track days.
I would like to find a way into the 11's with DR's and 12.5's with street tires. That's the goal anyway. Is that realistic? What do I need to do?
I don't know if I should use a taller tire or not. If I go taller I will not need to shift to 5th. I suspect though I will need to go slightly smaller, right now I'm only at the bottom of 5th crossing the line. Maybe taller for street tires and smaller for the track?
I did read all 13 pages and honestly I'm baffled and amazed. Mostly I'm just like how the F are they cutting these times.
The other thing is what's the best way for a long burn out, drop the clutch and then move your clutch foot over for a little brake to keep it going? It's a non issue right now but if I get some DR's then I'm gonna have to change what I'm doing now.
Thanks for any info you might throw my way. I know this is more of a here is what I got on the car and what it did threat but I know there is a ton of exp. here so if you could throw me a clue that would be awesome. My last car was a g8 and would KILL this one in the 1/4, I need to turn that around fast!
