Meziere WP346S Electric Water Pump w/ Idler & Relay Kit
Powered by Ford
Brand new in box Meziere WP346S electric water pump with idler & relay kit.
$350 shipped in the CONUS by UPS (no PO Boxes, APO’s, etc)
First pay, first serve.
irishpwr46
Official Site Vandal
NYC
whats the actual difference between this and the 347 besides it being listed for a supercharged application? just the pulley size?
Powered by Ford
According to a search I did the idler diameter is reduced for the wp347.
Sent from my XT1254 using Tapatalk
irishpwr46
NYC
I'm waiting to hear from meziere to see if the pulleys can be swapped. if they can, I'll take it
irishpwr46
NYC
its a no go, they actually said that in my case with a centri blower and a thump r tensioner it wouldnt be any good to get either one, i would have to get the 349s
Powered by Ford
That's cool glad you found out
Racer47
Doesn't have much to say
SE Wis
I looked into it a while back. The only real difference is a double bearing on the idler pulley. Not sure if its actually 2 bearings side by side or 1 double row bearing. The other part number differences are just pulley diameter differences. As far as I could tell any modular water pump would physically fit and work assuming you had the correct belt length for the given pulley size.
Department Of Boost
Alpha Geek
I don't see why you would need a double bearing. One of those bearings has a load rating a LOT bigger than the load they see.
irishpwr46
NYC
I'm curious why they said that. What's the difference?
he said that they were having a lot of issues with the added tension from the aftermarket tensioners and the superchargers. i also have an 18% overdrive crank pulley which was going to cause some clearance issues
