Morosso 7Qt Oil Pan
S281SC
Does anyone have the Morosso 7Qt Oil pan on there GT?
If so, how did you get the Oil temp sensor to fit the NFT plug?
Right now I have mine disconnected since the NFT plug is standard thread vs. metric.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I have a Moroso pan, and if I recall correctly, a new bung may have been welded on. I really don't remember for sure. It was shipped to Adam's shop during my engine build 2 years ago, and Mark (ChevyKiller) had the same pan. There was some discussion about that thread size, and at one point, Mark was going to take his and mine and get them modified. But I don't remember for sure if that is what actually ended up happening, or if Adam came up with a workaround. Sorry...
If it helps at all, here is what the finished product looked like.
ChevyKiller
Preferred Internet Drink
The problem was corrected by Ford. You had to weld a new bung for the mismatch sensor back then but Ford came out with another sensor that works and fits. We had this discussion at modular fords back then. I'm banned there but if you search it up, you can find the part #'s and all the info you need. Just search 'Morosso eliminator oil pan'
Good luck.
don_w
San Diego, CA
So, did you have mine welded Mark? Or did Adam get a new sensor?
fordracing
12.84@108 1.89 60' N/A
Eden, NY
Here is the part number for the sensor
F5AZ-12A648-AB
you will also need the pigtail for it.. I'm waiting on the pigtail to come in; when it does I'll post the part number for that as well (it was supposed to be here Monday)
pigtail number is
3U2Z-14S411-VA
S281SC
Thanks for the information everyone! I am ordering the sensor F5AZ-12A648-AB, Thanks fordracing! Do you have the pigtail Pn# for this yet?
fordracing
Eden, NY
I don't....If I can get it from Ford when I call today I'll post it for you.
RRRoamer
It would be nice if Moroso would make a 3V specific version of the pan with the correct bung on it. I would rather stick with the stock sensor than having to get a new sensor AND a wiring pigtail to make it match up to the stock wiring harness.
