Motor is gone
94tbird
4R70W FTMFW
all that seems left to do is align pulleys. I shredded a belt so badly last night it was amazing. I actually stopped the engine in mid shred and the status pf the belt was incredible.
I am gonig to change the oil to 5w50, gt500 spec, and reisntallthe meziere pump and as long as i can figure out the pulley alignment i should be ok
I have to say the gates laser alignment tool is shit, useless, crap and completely wrong, even after aligning the pos 27 times.
94tbird
4R70W FTMFW
Ok. finally got the laser worknig right.
Crank to AC - Perfect
Crank to PS - 1/2 rib off
Crank to blower - Perfect
Blower to Alt - Perfect
Blower to PS - 1 rib off
Blower to AC - Perfect
Alt to blower - perfect
Alt to PS - 1 rib off
Alt to AC - Perfect
Obviously the PS is off. Now last time we pulled the pulley out a small amount to align everything. Right now the PS pulley is flush with the pump and cannot go back any more. The laser says the pulley needs to go back more but from my experience last time this has got to be incorrect. pulling out away from being flush fixed it last time. how can pushing it in further be the fix this time, and if it is, how, cause its already bottomed out.
I took it for a drive and got on it a few times and shifted quickly to simulate what i would do at the track and all seems to be good, no noises or anything. Every now and then i do hear a slight squeal from a pulley, which has got to be the PS pulley but im not sure. Also there are no marks on the belt or belt dust either
As far as using the 5w50 oil, these are the pressures i see:
5w20:
Cold start - 85-90psi
Idle hot - 38-40psi
Load hot - 58-60psi
5w50:
Cold Start 85-90psi
Idle hot - 48-53psi
Load Hot - 78-84 psi
dustindu4
Is there any clearance between the PS pulley and the pump? Can you recess the back side to move it in a little and still have clearance? This would have to be done by a pro on a lathe obviously
94tbird
4R70W FTMFW
It is incredibly hard to take the pump out. almsot easier to pull the motor. it sucks balls which is exactly the reason when i took the motor apart i didnt remove it haha
Im still thinknig the laser is wrong in this though.
94tbird
4R70W FTMFW
well jsut took her out again
heres the story
Christina, the black Mustang, is back, and ALIVE and Kicking and just killed a Honda hatchback dragging Spongebob behind it. His excuse? the Spongebob doll created drag and slowed him down. That's a lot of drag to make up about 20 car lengths.
He actually said if he removed the 10" spongebob stuffed animal he could beat me hahahahahaha
one eyed willy
Pizzle fo shizzle
Lakeland FL
heres the story
awesome man,glad to hear your having some fun again.i had mine out last weekend around 1am,following a couple rsx's that were messing around.when i finally got up beside one he asked what i had done,i told him it was all stock,next light we just laughed,then i told him is was "mostly" stock.
dustindu4
I mean you said you moved the pulley before. Can you remove the pulley and modify it so that it moves back more towards the pump
94tbird
4R70W FTMFW
no it is as far back as it can go on the shaft. even machined it cannot go back further but it doesnt matter. Im leaving it as is. I can shift at high rpm, can powershift, have no squealing anymore and it seems to be perfect. Its staying until im forced to do something haha
Croft
It's GOOOOOOO Time
MD
Yeah, that's not good.........what's up?
