Jul 26, 2010 #1 B blacks197 Senior Member Joined Mar 4, 2008 Posts 920 Reaction score 0 Location Albuquerque,NM Anybody know what this plug goes to? Its hanging by the ac pump but the plug is different
Jul 26, 2010 #2 T TexasBlownV8 Formerly TexasBlownV6 Joined Apr 4, 2008 Posts 5,019 Reaction score 95 Location Central Texas A/C compressor. Pink wire, and black wire. Might not fit up to your compressor if it or the harness was changed.
Jul 26, 2010 #3 B blacks197 Senior Member Joined Mar 4, 2008 Posts 920 Reaction score 0 Location Albuquerque,NM i should be able to wire the right plug onto the wires then right?
Jul 26, 2010 #4 JeremyH 3V Fuel Guru Joined Jan 10, 2009 Posts 20,857 Reaction score 206 Location Virginia Beach Yes you should be able to. You can find the right connector you need here: http://www.s197forum.com/forum/showthread.php?t=30827
Jul 26, 2010 #5 T TexasBlownV8 Formerly TexasBlownV6 Joined Apr 4, 2008 Posts 5,019 Reaction score 95 Location Central Texas I know for a fact the plugs are different on '05 vs. '07. The wire is a little short, so peel back the loom enough and you can splice in the proper pigtail you need. (solder and heat-shrink tubing of course to make good connections.)
