Need Sideshot Pics of all 4 CJ springs vs Stock
AlbertD
Tucson, AZ
I've been searching the threads for a good pic of all 4 springs installed and can't seem to find any good examples. It seems like there are at least 5 or 6 CJ threads with pics of the springs or pics of just the rear springs, but none have a clear pic of all 4 installed vs stock. The only pic I've seen is Chad05GTs, is there any other out there? Thanks
AlbertD
Tucson, AZ
Here is a shot before vs. after. Tire sizes front 245/45s, rears 305/45s. It may just be me, but it does seem like it lowered the stance just a tad in the front and even a little in the back.
Before (Stock springs/Stock shocks & struts)
After (CJ springs all four corners, Tokico D-spec shocks & struts)
The ride height between the two is almost identical... The rear might be slightly lower.
I can seen a diffrence both front and rear, not bad at all. IM considering these cj's to get a little ride height back with the turbo piping, currenty have the frpp k springs. WOnder how the cj would do with the bilstein shocks/struts, also i dont have a front sway so im alittle worried about roll in the front.
AlbertD
Tucson, AZ
Well after I installed the springs (front sway removed as well), the car felt like a boat around town... I had to compensate for that by setting the Tokicos to a firmer setting. If your not planning on taking some hard turns, then I would recommend these springs. I only got one track outing with this new suspension setup so I'm still playing with different configurations. I did manage to beat my stock suspension setup 60ft of 1.63, ended up with a 1.61, so this setup is proving to be beneficial.
Some pics of front springs left to right, frpp k, stock, cj
Rear from left to right, frpp k, cj, stock
Bigmike0405
Whine and dine
PA
Prob I mod in the future for me as well. Looks good light blade:thumb:
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Boy that garage looks familiar, LOL!
Another succesful spring install without using a spring compressor...can't say enough how easy and safe this way is.
