New clutch & sticky shifter
vnikGT
Seattle WA
Hi folks
Thanks for all the clutch input from a previous post.
I did go for the Excedy Mach 350 clutch.
And a new flywheel.
It is a big difference from the previous one.
I do have a question.
I had a local clutch shop do the installation.
With a new clutch is the shifter smooth when changing gears or are they a little sticky or notchy during break in?
I did have a new throw out bearing and slave cylinder installed as well.
It the sticky shifter an install issue?
Your input is very appreciated.
Thank you
vink
