AutoXRacer
No, no breathers yet.
Lito will be adjusting the tune...
Your only solution now is to go dry sump![]()
I love the idea... I wouldn't do it though. I wonder if it would have been an option during the build.
What would be the benefit?
I think you're okay on the blow-by. If your compression checks out, I wouldn't be too worried. Just check the oil before you race and every now and then if you still daily drive it.stainless rings just beat the engine i go to the track or dyno run thats the only way they seat beat it and let the engine to cool down and again you my have to do it few times...
also i see too much gap for the oil ring
Who's cylinder heads do you have??? And don't count on small volume a/o separators to really do a great job. A dedicated tank w/ baffles would be ideal.
FRPP Stage 1 heads...basically stock 08-10 heads.
Some plugs are going to be wet. When you shut the motor off every cylinder is in various stages of the 4 strokes. Some are in the intake or compression stroke with the air-fuel charge in the cylinder but you shut it off before the spark ignited it.
