I put in a set of quick struts, they do not need to be torqued at ride height.
FACTORY Lower control arms, rubber bushings, the bolts should be torqued at ride height.
Sway bar bushings, doesn't matter, but you need to make sure
both wheels are at the same height so the bar does not move
on you when you remove either side clamp.
Bolts on these kind of bushings should be torqued ride height:
If you tighten these with the suspension hanging, they may be stressed at ride
height, and even more on uplift of the strut IF the sleeve doesn't slip and set; they will
wear/tear faster. The entire bushing twists first, rather than glide on the sleeve like with
poly. It's rest position should be ride height. Basically, torquing the control arm
bushing with the arm hanging; it will twist through a greater range of motion before
breaking free from the sleeve. It should break free, slip and realign itself, then lock into
the correct position. Under the same conditions though, a hot-bonded bushing will simply
fail.
Poly bushings are totally different. It really doesn't matter where the suspension
is when you tighten the bolts. The poly moves on the metal sleeve instead of sticking
to it like rubber. This is where the squeak comes from when the lubrication layer
between the sleeve and poly is not there. They work on the same basic principal as
main bearings do on a crankshaft... Anyhow, eventually, the center ovals out, where as
rubber bushings tear, or the sleeve stays free from the rubber and wears down every
time the bushing twists.
Sway bar bushings work the same way, the bar twists in the bushing, except for
like VW, Audi where they have roller bearings or plastic sleeves to twist in, and they
are attached/bonded to the sway-bar and need cut off if you were to switch to rubber
and clamps. Or, you have to buy the whole thing, sway bar with everything attched
for $280.
