Continuing with my suspension upgrade, I have received my UPR adjustable UCA and mount from...you guessed it, UPR. I will be installing them soon.
My only concern on the install is loosening the mounting bolt under the seat but, it will probably end up being of no consequence.
I was supplied with more washers than are required for my install and I only see a need to use one washer for the large, in-cab mounting bolt. If washers are supposed to be used on the UCA mounting bolt. It ain't long enough. Besides, a lock nut is utilized so, washers don't seem necessary.
I'm a little disappointed that I did not receive a UPR decal with this unit as I'm am quite positive this decal would knock of a few tenths in 60 foot times.
I've put together a few pics of it assembled in the way it will be installed, except for the big bolt, of course.
