New Vendor
PNR Welding
Hammonton, NJ
Thanks for the opportunity to become a vendor. There are some things that we are working on right now for our cars.
We make water to air tanks with internal pumps, catch can/breathers , and we are working on a fuel cell that will allow you to add a stock pump assembly to it so you can either save weight or it could allow you to run two types of fuel. No more changing fuel at the track. (Maybe even run both tanks like the first gen lightning do). We need to do testing.
Here are the water tanks that we are selling.
If there is something you want to change on it, please Let me know and I'll make it the way you want.
Trunk mount ice/water tank with pump installed.
6" lid for water and ice.
Comes with 3 brackets for install in trunk.
3 bungs installed.
Feed and return are 1" npt, drain is 3/4"npt.
Holds 7gallons
Half moon tank prices
275.00 shipped no pump. 5.5 gallon
320.00 shipped with rule 1100. 5.5 gallon
400.00 shipped with rule 2000. 7 gallon
12x12x10 tank. 5gallon
215.00 shipped no pump
240.00 shipped with rule 1100 pump
300.00 shipped with rule 2000pump
375.00 with rule 3700 pump (1.250) bungs feed and return
Polished and Powdercoated options are available.
[/QUOTE]
These are 12x12x10 with pump
dysan
Dis-Member
Williamstown, N.J.
Congrats on becoming a vendor.
Paul and I will be the test mules for the fuel cells since we live very close to each other. Both our cars are becoming track only cars so weight savings is a must (at least for me).
Sounds good, I'm defiently interested in trunk mount cell that retains the stock style hat. And ditch the stock saddle tank! That would be awesome, drop weight and shift it back.
johnnyv8
South Jersey
Thanks man,
Let me I know if you need anything done with your turbo kit or any issues needed to be fixed.
I still have some minor stuff going on. I'm thinking the eboost and a new set of mufflers (my current ones are chambered) will fix it all. I'll keep you updated! I'm either going to build this motor or get a GT500!
weather man
Persistence Is A Bitch
MN
Coolant overflow that mounts in the battery spot with NHRA legal 1 pint overflow something you could do? 08 Mustang GT.
06gtmustang
ABQ NM
Also interested on how much that trunk mounted fuel cell will run for. Good looking work man!
