83-88T-Bird Guy
O.K.
I'm about to pull the trigger on building one or the other.
1. A 2009 (or) 2010 Mustang GT Stocker with the 4.6 3v. I have not seen one yet or heard of anyone building one yet.
or...2. A Super Stock GT car with a 3V engine in my 86 Turbo Coupe.
Either way, the idea is to build it to Stocker engine specs and try to run under the index for either class setup.
This combo is all N/A and we have to run within the published specs and casting numbers.
That's where I need the experienced help of the 4.6 3v guys.
According to the Wallace website calculator, the 4.6 needs to make at least 435 fwhp to run the index of 11.75.
As a Super Stocker:
* The raceweight would need to be 3460 lbs.
* The index for the class is 11.75 .
* The heads would be the FRRP CNC Hot Rod heads
* The required throttle body is the twin tb 62 mm ( 2010 CJ ) spec
* Max valve lift is .473 for intake and ex.
* Stock Ford pistons ( 3.8 cc dish) stock stroke
* I want to pull this off with a stock '05-'10 intake
* Transmission would be a C-4.
* Not sure of the rear gear but probably 4.30's or 4.10's.
* Race fuel ( we have to run a fuel on the approved list)
Stock Eliminator spec chassis.
The only power acc. would be the alternator.
Now...could that engine make 435 h.p on motor with the stock intake, 62 mm tb, and .473 lift cams ?
Note: the cams are allowed to have any amount of duration, but the gross valve lift checked at the valve must not be over .473 ".
I am pretty sure this engine could run the index in Stock Eliminator of 12.65 @ 3680 lbs raceweight.
I would love to get it to run the S/S 11.75 index tho.
As a Super Stocker:
