NIB Steeda HD Upper Strut Mounts
viciousride
Needing more power!
Miami, FL
SOLD - NIB Steeda HD Upper Strut Mounts
Selling NIB Steeda Heavy Duty Upper Strut Mounts.
The Steeda street heavy duty upper strut mounts are manufactured to the same exacting tolerances as our industry leading caster/camber plates. They utilize a roller bearing that exceeds OEM specs to ensure precise suspension control. Will not fail on lowered cars like the factory piece.
These upper mounts eliminate the "popping" sound that is common on lowered cars when the factory upper mount fails. Unlike the factory piece, you can also get an extra 1 degree of camber in each direction with these plates as well. Steeda's heavy duty upper mounts are specifically designed for street use and will not show any increase in NVH when installed.Price includes a set of two.
Product Benefits
  • Better handling with more stable cornering, while maintaining factory ride quality
  • Precision Tolerance and Fit with the Highest Grade Materials available
  • Allows adjustment of up to 1 degree positive or negative of camber.
Fits Vehicle Model
Ford Mustang GT & V6
Fits Model Year
2005, 2006, 2007, 2008, 2009, 2010
Steeda info here: http://bit.ly/98VbDG
$230.00 Shipped!
