No Crank, No Start After Recent SCT Tune
Oliver Vigil
Did you check for power at the starter on the small terminal when cranking engine. Start with the basics.
Haven't been able to yet, been super busy. I plan on inspecting it this Friday. I'll update everyone. So far I got in contact with SCT and my stock tune clears out.
miltonmegilliii
Learning the ways.
have you checked all the fuses and relays? i briefly looked at the 2105 fault and it can be related the the pcm not seeing something correct with the drive by wire system causing it to not start or not accelerate. check all the fuses and relays. stick to the KISS method first.
Oliver Vigil
So figured it out and the solution was pretty hilarious. The issue was not related to the recent tune up however the nut holding the ground to my starter had called off. I installed a new nut and it runs perfect! I appreciate everyone's help, thank you all!
miltonmegilliii
Learning the ways.
@Oliver Vigil glad you figured it out. ive been caught up so many times with an issue thinking it has to be something difficult. you spend forever chasing your tail only to find something simple.
DieHarder
Grounds, grounds, grounds. Seems like we run across this repeating theme more than any other issue (save radiator fuses/relays). Folks, start with the basics and take it from there. YKY
