Any recent weights with the new drivetrain, before ballast?? Curious to see how the 347+TKO stacks up against the 4.6 4V and 5-spd. Did you happen to weigh the 4.6 motor when it was out, or anything else?
Terry, I'm thinking a stock 4.6 w/ the 3650 trans will be heavier than the pushrod engine and tko600. Unfortunately my scales were not working when I took the 4.6 out. But I sold it, and when I weighed the shipping crate it weighed 810 lbs. That was for a palletized crate, the fully dressed engine, the trans, flywheel/clutch, and the wiring harness. No headers. I doubt my crate weighed much over 100lbs, it was pretty basic. I weighed my boss block 342, fully dressed except for the carb, with the tko600 attached, and LT headers, and it was right at 605lbs. So I'm hoping to be some 100lbs+ lighter with the changes...
The stupid wiring harness weighed 35lbs by itself...
I scaled the car right after I bought it, and it weighed ~3400 with 1/2 tank of fuel and me in it.
Stock 4.6 as driven at VIR 5/12
962 856 53%
834 743 47%
53% 47%
As soon as the new front lower control arms come in (the package from BMR Tech) I'll be able to assembly the front suspension and get it on the scales. Really interested to see what she scales out at...
Then I'll add ballast to get the weight where I want it, depending on how the engine dyno's with the new exhaust...
I've got a set of Moton ClubSports going on the front. Did you drive your car with your shocks on it before you sent them to Moton for the new pistons, etc?? I spoke to one of the guys at Moton a couple of months ago and he said run the struts "as is" for now, then rebuild down the road. I bought them 2nd hand this spring, looking forward to trying them out. Plan to start w/ 600lb springs then go from there. The car came with Ground Control struts and 700's on it, which worked fairly well the one time I had the car out at VIR...
Oh, one pleasant surprise on the build... by swapping out my 05 pinion flange for the one off the fox 8.8 I was able to use my already shortened aluminum driveshaft off the fox. The length was perfect as is... One less thing I had to spend $$ on...
