The Big Herm
Build in Progress
Oh...and I had the heat on.
I had that same heating issue long ago too.. it took 2 times bleeding the system from the cross over and squeezing hoses like they were tits. If that doesnt work I would get that term as stated. 160/170
Does it overheat without the AC on? Could be an issue with the compressor.
explain please....
My old DD had an issue with the AC compressor but I didn't know that at the time. I did notice that the engine temp was higher than normal. I didn't see anything until the compressor locked up and stalled the engine at a stop sign. While trouble shooting it on the side of the road I took the belt off and the car started and ran. I was able to get home on battery and then isolated it to the AC. Once I replaced the compressor the engine temps dropped back down.
Alright, so I did a thorough search before I decided to post this. I am up in arms about what could possibly be causing this so I am hoping someone has some good advice.
I have a procharger on my 05 GT. Running 14 PSI currently on an 8-rib pulley. Lately, I have noticed that my car has been running hot everytime I turn on the A/C. Granted, I live in TX where yesterday the temp was 110. The AC blows WARM air and the car immediately starts to rise in temperature. I shut the car off, of course, before it gets too hot. The car is not losing any anti-freeze/coolant but runs hot and smells like anti-freeze. Any suggestions?
The only thing that I could think of was the thermostat was stuck half way or the water pump isn't pumping enough for the increased work. I am so lost.
Thanks in advance for any help!
