Passing inspection in NJ
RideThePony14
NJ
So I just failed my inspection for the second time today. The readouts say that the catalytic converters and o2 sensors are "not ready". I currently have an o/r xpipe, CAI, throttle body, CMDPs and a tune. I called up AM after I failed my first test and had them send me a tune that leaves the rear o2 sensors on (I did the spark plug non fouler trick and it works) hoping that that would make the sensors respond, but it didn't. I go to this place that only does the computer check, no visual inspection. Putting back the stock exhaust would be a real PITA for me and my inspection is already overdue. I know this topic has already been discussed lots of times but I need a specific quick answer. Thanks.
james05gt
NJ
I passed nj inspections with no cats using the non fouler trick with rear o2's on. Make sure that the rear o2's are really on on the tune. Then follow http://www.obdii.com/drivecycleford.html to get the readiness monitors "ready" You can use a handheld scanner to see what monitors are ready and not ready.
RideThePony14
NJ
Did you use the scanner yourself? Could I do this with a handheld tuner (SCT iTSX)?
fdjizm
Drag Queen
NY/NJ
Did you drive around a bit? I had to do a 40 mile trip with mixed driving to get mine ready.
Also using non-foulers and a tune with the o2's on, passed the obd test perfectly.
james05gt
NJ
I have one of those cheap actron scanners from advance auto, it has a drive cycle monitor option which you can actually see the status of your readiness monitors. Not sure about the sct itsx. I know my sct x3 doesn't have it, it only checks and erases dtc's.
RideThePony14
NJ
I drove probably 60-80 miles after I uploaded the tune from AM, but that didn't seem to work. They're sending me a new tune so hopefully the third time is a charm...getting real sick of paying $60 every time.
fdjizm
Drag Queen
NY/NJ
It doesn't matter if you drove 100 if you didn't get through the OBD drive cycle, you have to drive how it states up above.
I got through it in 40 miles on empty roads and in traffic.
Are u sure the rear o2s are turned on?
Rob72
No Japanese Mustang Here
Baltimore, Marxland
In my drivers manual under the emissions section it says let the car rest 8 hours, then 15 minutes nonstop expressway driving followed immediately by 20 minutes city driving which must include at least four 30 second idle periods.
RideThePony14
NJ
The AM tune is supposed to turn them back on. I'll I through that drive cycle and see if that works. Thanks guys.
