Status
Not open for further replies.
JDCoon
Jena, LA
330- Cubic inch displacement (CID) of engine
BTS 4R100- Type of transmission (by model number)
3.4 Whipple- Size and Manufacturer of power adder, or N/A
22 psi- Pounds of Boost, of N2O shot (or both if applicable)
3.73- Rear Gear ratio
MT pro radial- Make and type of tire
timfoster405
Maryland
2013 Mustang GT Automatic - Factory Stock
1) copy of timeslip--See attached
2) The following vehicle information: 100% Ford Factory Stock down to the tire pressure
timfoster405
Maryland
2012 Ford Mustang V6 Automatic - 3.31's Factory Stock
2) The following vehicle information: Factory Stock V6 auto, down to the tire pressure
3) traded in for '13 GT
DTony
Ohio
2011 Mustang.
Boss short block
Boss intake, stock heads and cams
Headers and X pipe
3.31 gears, 3600 converter
Vortech at 12 lbs. 3840 race weight.
MT Drag Radials
GT.350-R
3PEDLS
Portland IN.
2007 GT
281 cu in
Stock Heads , cams and intake
Stock 3650 Trans and clutch
4:56 gears
M/T Drag Radials
As you can see on the time slip, the 12.06 was on the breaks to win the race, but broke out anyway.
JDCoon
Jena, LA
Sactown
Sactown
Sacramento, CA
That is seriously nasty 60'!
psfracer
billy badass
Valencia, CA
Did you get out of it on the big end? Your back half mph is a little low for a s/c car at 22 psi. I would have expected something more along the lines of 30 mph or so, but your back half mph is only 25 mph. Perhaps the converter is not locking? I am not really familiar with the 4R100 trans, does that use the same converter as the 4R70W?
JDCoon
Jena, LA
I think my convertor may have slipped a little, i have several other passes ranging in the 139-142 range. The convertor is locked in all of third gear. Convertor is a lil different than a 4r70s. We plan on pulling the tranny and going thru it and the convertor to see exactly what kind of wear we are getting and possible some convertor change over the winter.
May have let out before the mph stripe as well tho.
retfr8flyr
The Old One
Providence Forge, VA
New personal best before my car caught fire.
- Cubic inch displacement (CID) of engine. 281
- Type of transmission (by model number). 5R55S automatic
- Size and Manufacturer of power adder, or N/A. Twin Comp Turbo CT3 6062 Oil-Less turbos
- Pounds of Boost, of N2O shot (or both if applicable). 15# of boost 93 pump gas
- Rear Gear ratio 3.27
- Make and type of tire MT Street Radial II 295/45/R17
Earl
jodadejss06gt
TEAM DELETE SHIT
Severn MD
New PB backed up.
Changes are ID1000's, twin 405's, E85 and 10psi, 3580 with me in it.
Stock 3650
Stock Gears
Eaton Tru Trac
RST
Stock Heads
Stock Cams
67mm Turbo
Status
