Status
Not open for further replies.
wbt
- Cubic inch displacement (CID) of engine
302 - Stock long block Coyote
- Type of transmission (by model number)
Automatic 6R80
- Size and Manufacturer of power adder, or N/A
N/A
- Pounds of Boost, of N2O shot (or both if applicable)
N/A
- Rear Gear ratio
3.31
- Make and type of tire
Hoosier DOT Drag Radial
My apologies on the tardiness for the update:
Everything is the same on mods. Updated times:
A few pics:
dirtfan71
Marshfield, MO
2006 GT stock except cai and Bama tune. March of 2012.
3v 4.6 stock
5 speed stock
N/A
N/A
- Rear Gear ratio
3.55
Nitto 555 street tire
brianadams03
Madison, MS
New pb:
12.09 @ 115.31 w/ 1.75 60'. Run before squeaked out a 1.67 60' but unfortunately didn't have my 1/4 time on it.
Mods:
This pass was with:
--3.73's
--Boss 302 Intake Manifold
--JLT CF CAI
--93 Lund Tune
--GT500 ab's
--Lethal O/R X-pipe
--Mach 600 Clutch
--SR Short throw shifter
--Dark stars w/ Hoosier QTP'S 27x10.5x15
djniknala
New Best
Ran [email protected] with a few new mods.
Stock intake
Boss manifold
Boss clutch and flywheel
Steeda poly motor mounts
47lb injectors
E85
Tuned by AED
1.49 60 with a 7500rpm dump. I got a couple 1.47 60's but the passes weren't as clean. DA was worse than my previous 11.53@118
[email protected]
Second slip backing it up [email protected]
Stock 302 4V
Stock MT82
NA
3.73
Hoosier stiff sidewall slick 28x10.5x15
05stroker
Never enough power guy!
Bullard Tx.
10.1 congrats man. I cant wait to line up next to you
more then likely sent fron Dairy Queen mmmmm blizzards
Not to far away.
10.10 @ 133, pretty good on the 20s.
Is this on the race tune or pump gas?
Race tune with a 20 mph head wind. Man I wish the wind would have been less. For an example the car will usually run a 137-139 trap speed on this tune.
Wow...awesome. What gear are you running? How much boost?
4:10s and about 20 psi.
EDIT: Here is what I posted in my thread.
I will get the in car videos up tomorrow but here is the new PB on the 20s. If only there was not a 20 mph head wind I would have made the 9.9x! I was also having trouble with the AEM Trueboost. The right button doesn't work and I have the over boost feature set at 20 psi. It will go back to WG spring pressure when it senses an over boost condition. I tend to hit 20 psi in 1st, 22 psi in 2nd and 22-23 psi in third. So on these runs I was only at 16-18 psi (spring pressure) in third and had a horrible head wind. Fun none the less though! Oh and how about those 1.50 60 ft times!!!
psfracer
billy badass
Valencia, CA
Holy crap! 9 second car for sure. Is the 10.10 currently your quickest?
Fabman
Children Of The Corn
Pleasanton, Ca.
Damn that is flat out impressive on a 3 valve.
Do you have a mod list somewhere? I'd love to see what I'm missing.
05stroker
Bullard Tx.
: Engine
· 05 up Ford aluminum block
· Manley 18cc dish pistons 9.0/1 .030 w/ ceramic coated tops and dry film coated skirts
· Manley Billet Pro Series rods coated w/ PD14
· Kellogg 3.75 stroker crank coated w/ PD14
· Federal/Mogal Race series bearings dry film coated
· ARP 3v head studs
· ARP 3v main studs
· Livernois vct lockouts
· Comp Cams 127550 cams
· Comp. Beehive springs moly coated with titanium retainers
· Ported heads with 35mm in. and 38.5mm ss valves with all ports, chambers, and valves ceramic coated
· Steeda delete plates
· MMR windage tray
·Ford GT500 oil pump w/ TSS billet gears
· Ford head gaskets
· New Ford timing chains, guides, and 2v tensioners
· Moroso 7qt. oil pan coated with PD14 inside
· MEZIERE elec water pump
· Autolite HTO plugs
· Innovators West Balancer with custom Procharger crank pulley and crank support
· MSD COPs
· MSD dual Dis 4 setup w/ 2 step and ign. Kill
· JPC sheet metal intake urethane coated by Polydyn
· FRPP polished throttle body
· Crank case evac. System and Morso breather tanks
· Remote oil filter
· Rear head coolant mod
: Power adder
· Procharger F1a with 12 rib pulley .Blower inlet and all piping ceramic coated outside and PD14 coated inside
· Procharger Red Race valve and 44 mm wastegate
· Procharger 800 hp intercooler
· Custom 4” CAI with filter located under headlamp
· Custom Billet 12 rib setup
· HSW N2O wet kit with polished bottle, bottle opener, perge, blow down tube, Microedge, and all black and silver ends
: Engine compartment
· Derale 16 pass oil cooler
· Derale 4 pass PS cooler
· Battery relocated to trunk , mounted in polished alum box
: Exhaust
· ARH ceramic coated headers 1 3/4 tubes w/ 3” collectors
· ARH 3” O/R x-pipe ceramic coated
· Magnaflow 3”cat-back
: Fuel system
· Fore return triple pump hat with 3 Ford GT pumps
· FRPP 62mm TB
· Fore fuel rails
· Simem Deka 80lb injectors
: Transmission
· Lentec Strip Terminator w/ TB and AVB
· Lentec Billet 3800 stall
· Trickflow alum. Pan
· Duel Derale 16 pass trans coolers
· Outlaw shifter
· 1 pc. Steel driveshaft w/ Chromalloy yoke and flange
: Rearend
· Ford 8.8
· FRPP 3:73 gears
· Detroit True Track
· 04 style pinon yoke
· Moser 31 splineaxles
· Moser rear cover with bearing supports
· Welded tubes
· C-clip eliminators
:Tires
· Front tires : BFG G-Force 245/40zr/20
· Rear tires : Nitto NT05 315/35/20
: Suspension
· Totico D-Spec adj. shocks
·Eibach Sportline springs
· BMR adj. UCA
· BMR LCA
· BMR LCA relocation brackets
· BMR adj. panard bar
· BMR panard relocation bracket
· BMR panard brace
· BMR k-member
· BMR tubular a-arms with updated bushings
· BMR rear extreme anti squat
· BMR boxed sub-frame connectors
· BMR upper poly bushing
: Brakes
· Bear 14” rotors
· Hurst line lock
· Braided SS lines
: Interior
· Custom 5pt roll bars with removable side bar
· RCI 5 pt. harness
· Custom switch panel in console for
N2O arm
Dash controls
Ign. Cut off
O/D arm
Perge
Bottle opener
N2O gauge
Microedge controller
AEM Trueboost
· Autometer gauges
Trans temp.
Water temp
Oil Psi.
Fuel Psi
W/B
Tach with shift light
Status
