Status
Not open for further replies.
Fabman
Children Of The Corn
Pleasanton, Ca.
: Engine
· 05 up Ford aluminum block
· Manley 18cc dish pistons 9.0/1 .030 w/ ceramic coated tops and dry film coated skirts
· Manley Billet Pro Series rods coated w/ PD14
· Kellogg 3.75 stroker crank coated w/ PD14
· Federal/Mogal Race series bearings dry film coated
· ARP 3v head studs
· ARP 3v main studs
· Livernois vct lockouts
· Comp Cams 127550 cams
· Comp. Beehive springs moly coated with titanium retainers
· Ported heads with 35mm in. and 38.5mm ss valves with all ports, chambers, and valves ceramic coated
· Steeda delete plates
· MMR windage tray
·Ford GT500 oil pump w/ TSS billet gears
· Ford head gaskets
· New Ford timing chains, guides, and 2v tensioners
· Moroso 7qt. oil pan coated with PD14 inside
· MEZIERE elec water pump
· Autolite HTO plugs
· Innovators West Balancer with custom Procharger crank pulley and crank support
· MSD COPs
· MSD dual Dis 4 setup w/ 2 step and ign. Kill
· JPC sheet metal intake urethane coated by Polydyn
· FRPP polished throttle body
· Crank case evac. System and Morso breather tanks
· Remote oil filter
· Rear head coolant mod
: Power adder
· Procharger F1a with 12 rib pulley .Blower inlet and all piping ceramic coated outside and PD14 coated inside
· Procharger Red Race valve and 44 mm wastegate
· Procharger 800 hp intercooler
· Custom 4” CAI with filter located under headlamp
· Custom Billet 12 rib setup
· HSW N2O wet kit with polished bottle, bottle opener, perge, blow down tube, Microedge, and all black and silver ends
: Engine compartment
· Derale 16 pass oil cooler
· Derale 4 pass PS cooler
· Battery relocated to trunk , mounted in polished alum box
: Exhaust
· ARH ceramic coated headers 1 3/4 tubes w/ 3” collectors
· ARH 3” O/R x-pipe ceramic coated
· Magnaflow 3”cat-back
: Fuel system
· Fore return triple pump hat with 3 Ford GT pumps
· FRPP 62mm TB
· Fore fuel rails
· Simem Deka 80lb injectors
: Transmission
· Lentec Strip Terminator w/ TB and AVB
· Lentec Billet 3800 stall
· Trickflow alum. Pan
· Duel Derale 16 pass trans coolers
· Outlaw shifter
· 1 pc. Steel driveshaft w/ Chromalloy yoke and flange
: Rearend
· Ford 8.8
· FRPP 3:73 gears
· Detroit True Track
· 04 style pinon yoke
· Moser 31 splineaxles
· Moser rear cover with bearing supports
· Welded tubes
· C-clip eliminators
:Tires
· Front tires : BFG G-Force 245/40zr/20
· Rear tires : Nitto NT05 315/35/20
: Suspension
· Totico D-Spec adj. shocks
·Eibach Sportline springs
· BMR adj. UCA
· BMR LCA
· BMR LCA relocation brackets
· BMR adj. panard bar
· BMR panard relocation bracket
· BMR panard brace
· BMR k-member
· BMR tubular a-arms with updated bushings
· BMR rear extreme anti squat
· BMR boxed sub-frame connectors
· BMR upper poly bushing
: Brakes
· Bear 14” rotors
· Hurst line lock
· Braided SS lines
: Interior
· Custom 5pt roll bars with removable side bar
· RCI 5 pt. harness
· Custom switch panel in console for
N2O arm
Dash controls
Ign. Cut off
O/D arm
Perge
Bottle opener
N2O gauge
Microedge controller
AEM Trueboost
· Autometer gauges
Trans temp.
Water temp
Oil Psi.
Fuel Psi
W/B
Tach with shift light
THANKS!
sharkbaits
Just wanted to update our N/A Times in our red coyote stock car-
http://www.youtube.com/watch?v=ML1KZEUhn0Y
2) The following vehicle information:
- 302
- 4v Coyote Sealed Stock Engine
- MT ET Drag
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
302 Cubic Inch
6r80 Automatic
Vortech YSI
27 PSI
3.31 Gear
275/60/15 MT Drag Radial
05stroker
Never enough power guy!
Bullard Tx.
New PB
New best today on the 20" drs!
Lots of headwind (20 mph) so the MPH was down but, you get the idea. LOL
Clipboard
302 4v coyote
N/A no mods
3.55 gear
mt82 m6
335/50/18 perelli
brianadams03
Madison, MS
New pb:
12.03 @ 117.16 w/ 1.65 60'.
Mods:
302 4v coyote
N/A(mods below)
3.73 gear
mt82 m6
Hoosier QTP'S 27x10.5x15
Mods:
--Boss 302 Intake Manifold
--JLT CF CAI
--93 Lund Tune
--GT500 ab's
--Lethal O/R X-pipe
--Mach 600 Clutch
--SR Short throw shifter
--Dark stars w/ Hoosier QTP'S 27x10.5x15
Status
