Status
Not open for further replies.
fdjizm
Drag Queen
New pb on a breakout bracket run lol
12.571
Sharad
Site Sponsor
Fort Myers, Florida
1) copy of timeslip--if you don't have it, unless you have video, forget it. If you only have video, please provide the 60', 1/8-mi and 1000' incrementals
2) The following vehicle information:
- Cubic inch displacement (CID) of engine
- Type of transmission (by model number)
- Size and Manufacturer of power adder, or N/A
- Pounds of Boost, of N2O shot (or both if applicable)
- Rear Gear ratio
- Make and type of tire
3) your time also has to be backed up by another time within 2%.
2011 Mustang GT, 302 cu in, the entire engine is stock, MT-82, N/A, 3.31 gear, 275/40-18 Nitto NT05 street tires
Best pass was:
1.955
5.287
7.976 @ 91.85
10.275
12.209 @ 116.51
and backed up by a 12.292 @ 118.53. All timeslips are posted above.
Here is the only video we have. It's the fourth pass and it was a BAD bog.
First run on the new motor today. Lots of room for improvement but in the meantime I still ran my fastest times to date. It was 85 degrees as well, so a cool 60 degree evening will produce times about .4-.5 faster.
Engine is a JDM 302E Stroker (3v)
T56 Magnum transmission
VMP TVS1900 blower at 11 lbs boost
3.73 gears and Hoosier QTP tires
R/T --- .208 ---- .103
60' --- 1.695 ---- 1.722
330 -- 4.764 ---- 4.809
1/8 -- 7.229 ---- 7.288
MPH - 99.60 ---- 98.79
1000- 9.349 ---- 9.418
1/4 -- 11.120 ---- 11.192
MPH - 127.93 ---- 127.80
Was crowded today and waited all day for two passes. Would have been 4:30 or later if I tried to wait for another pass. Too hot anyway.
GTAmuscle
Colorado
For whenever the 3V N/A gets updated:
12.814 @ 106.48
-281CI
-5R55S
-Stock heads, stock cams
-N/A
-4.10 Gear Ratio
-Mickey Thompson ET Street Radial 275/50R15
62 degrees tonight, got my 10 second time slip and then some. This is what 20 degrees difference can make.
I don't have a two step and normally just rev it up by ear when the lights start. I've always aimed for about 5k but I guess I haven't been revving it up that much. On the last pass I looked down and saw I was only at 3500 so I revved it up a bit more before launching. Traction at Orlando is so good that I always dead hook regardless of how I launch.
Does this mean you're gonna update the 3v lists soon? :beerdrink:
psfracer
billy badass
Valencia, CA
Yeah I have to. I have a bunch of time off coming up and will have time.
Maybe I can do it Sunday evening.
confuzed
2014 gt a6
3780#
Tune
Drag radials
OR xpipe
Stock 3.15 gear
Stock manifolds
Stock mufflers
Stock air intake
[email protected]
11.97@ 119.49
Stock converter
Falkinman
New Jersey
Great runs confuzed! What were your sixty foot times and what drag radials did you use? Have you made passes with the stock tune? What did it run?
confuzed
Thanks 1.83 60ft
Nitto 05r 285/40/18
13.06@112 stock but horrible pass and spinning. 12.8-12.7 shouldn't have been a problem.
confuzed
No indeed, it would've easily gone a 12.8-12.7 prolly better.
My buddy's car runs same tune as me, nearly identical as me before I put xpipe.
He got 12.6 without tune.
12.13@118 just tune, I ran 12.09@118 tune only but with nittos
Tune and xpipe prolly worth .5-.6 tenths
Status
