Pro star fitment
Jperezav2009
Ok guys bare with me. Just picked up Greg weld pro stars
15x 10 and 15x3.5 the 15x10 have a 6.5 backspacing. Just tried to mount them but looks like it rubs brake. Will grinding down brake help out with fitment issue or will spacers help?
Jperezav2009
Iam aware of the sway bar relocation. But it grinds with caliper. Would a spacer hell or should I just grind it down?
Jperezav2009
here is pic of rims. Not sure what model they are.
SlvrS197
You need a 7.5 backspace on the 10 inch wheels also. They will probably stick out some.
Jperezav2009
Grinded down the calipers a bit. But now cant get lug nuts on because the holes on rim are either too close too wheel stud. Can only get one lug nut on and cant even get a thread on any of the others.
Jperezav2009
So I need to order longer studs inorder to get these wheels on. Got it. Also found out they are dragstar and not pro stars.
Jperezav2009
So the fronts went on well with spacers and all lug nuts went in without a problem.the rears are clear from brake calipers, but can only get one lug nut on. Can fit the other lug nuts in. Any help or suggestions?
