Procharger Issue ....
whyask
NORCAL
Ok so under the car i was noticing an insane amount of oil being sprayed out of my Big red race blow off valve .. so i took the lower piping off and noticed a small amount of oil just sitting in the pipes ... this is the piping comming off the procharger going to the intercooler,.... NOW, Im trying to figure out if the seals are going on the damn thing or is just oil being sucked in from the intake valve comming off the passenger side head ...?? would an
Oil Seperatior like from JLT do any good..?? ANy help would be great guys im on vacation for 3 more weeks and the faster i fix this the better ... this is my DD ;)
-Justin
19COBRA93
Ford Racing
Clinton, Ut
-Justin
I had the same issue. It's pulling oil from your head through the little hose to your inlet pipe. I installed a separator in that line and my oil "sucking" has pretty much stopped. So yes, install a separator, or run breathers on both valve covers and ditch the line running from your valve cover to your blower inlet.
Also, pay attention to the color of the oil, and the oil level in your head unit to make sure the head unit is not the source.
whyask
NORCAL
Awesome ! Yeh I just changed the oil today and it was clear ..very little but none the less clear, filled it back up to 6 oz as directed and ill check again..
Jeffs FRC
Bartlett IL
Go with a breather setup and dont look back... That way you can be 100% sure there is no oil getting into your intake.
Marc s
NASA AIX
Auburn, WA
I agree that it's probably oil coming from the engine vent hose. Mine was doing the same thing until I installed a catch can with a breather on it.
whyask
NORCAL
I love hearing good news , just trying to find a passenger side breather :)
Marc s
NASA AIX
Auburn, WA
I went this route and tied both valve covers into it.
whyask
NORCAL
what side did you guys put the oil seperator on ..? Passenger side or Drivers side ..?? I have the Husky oil filter mode on the passenger side right now but wasnt sure were i should put my JLT one at ??
whyask
NORCAL
Awesome I'll see how much oil the collector gets then probably upgrade to the higher end collector ;) thanks for all the great info
jjjferro
NJ
I had the same issue even with the oil seperator. I was advised by Mike from BDP to go with breathers all the way around. No issues since.
whyask
NORCAL
how do you do breather since the intake going into the procharger is pulling from the passenger side ...?? Can you post a pic if you can ...... Thanks
-Justin
fdjizm
Drag Queen
I think you just plug the intake, I plain to use breathers as well.
Jeffs FRC
Bartlett IL
mine too. took care of almost all of the oil problems I was having.
I had the same thing with the catch can. It almost worked for me too... Then I got smart and bought breathers for cheaper than a catch can and now I have 100% NO oil getting in my piping or intake mani
Like I said, get breathers and be done with it!
-Justin
Order 5/8" and 3/8" K&N breathers. They can be bought almost anywhere. Check summit or jegs. I also went with a CFM oil filler breather. http://focus.c-f-m.com/cfmbilletvalvecoverbreatherkitfor2005-08fordmustanggt.aspx
Install the breathers and plug everything else off... Its really simple and you'll NEVER EVER have to worry about oil where its not supposed to be again! :highfive:
19COBRA93
Ford Racing
Clinton, Ut
The only issue I have with all those breathers is they tend to "drip" oil from time to time. I'd much prefer to run the separator/breather that Mark has on his. My inline catch can does a pretty good job, but I intend on running the same setup as Mark.
