Project Kama Kaase (Ka-zee)
nice Paul! why wait till the weekend to get it in? :poke:
Matt D
S197 Pilot
Toronto,Canada
wow that 9" rear end is really that light o_O the spool is like a 20 lbs differnce from the locker I beleive. Still surprised me lol
Looking good Paul, no gun drilled axles?
psfracer
billy badass
Valencia, CA
No I didn't spring for that. Maybe I should have, but I have so many other things to get. I called Kaase today and the heads where going out today, so hopefully the motor will get started here pretty soon.
psfracer
billy badass
Valencia, CA
Nah, don't need it.
Wait....a box just showed up with "02102" on the side. Maybe I will need it.... :whip:
Chris06GT
Dragging LS A..
Alabama
Looks good Paul!!!
I don't believe those studs wheel hold too good though......bahahahahaa!!!
94tbird
4R70W FTMFW
NY/NJ
Took out the spare tire well today:
Mocked up the 6061 aluminum brackets I had cut to size. This is what it will look like underneath, I just placed the fuel cell on top, but it actually will be on the other side--where all you will see in the trunk is just the sheet aluminum. The big bracket to the right of the fuel cell is where I am going to mount the Aeromotive A2000 pump and filter. The L brackets on each end will be bolted to the frame--as required by the NHRA rulebook.
The fuel cell is powdercoated black and has two outlets, a rollover checkball vent, and a return line. I am also using all grade 8 bolts, as last time I attached some ballast to the frame with grade 5 bolts-- the tech guys REALLY did not like that, at all.
Here it is mocked up without the aluminum sheet metal in place. Going to do that tomorrow. Once the aluminum sheet is in place, you won't be able to see any of the brackets unless your under the car. The arrows below show how I am going to bolt everything to the frame.
What did the cut out spare tire well weigh? Awesome rear end. Ive got a Currie 9" as well for i think 3 years now. Hasn't given me one ounce of trouble except some leaking oil which is resolved with these new bearings i got.
psfracer
billy badass
Valencia, CA
Not very much, but I didn't weigh it so I don't know for sure. The weight savings was actually removing the stock fuel tank---which completely empty was 35lbs by iteself. If I had to guess, the spare tire well was maybe 10lbs or so---it is pretty thin metal.
psfracer
billy badass
Valencia, CA
Talked to Jon Kaase Racing today---my P51 heads went out today, and I ordered a custom nitrous cam (which still will run good N/A)
.780 lift on intake and exhaust, duration 274 @ .050 intake, 280 @ .050 exhaust on a 112 lobe center. Note that those duration numbers are not the "advertised" number, which is meaningless as how that is computed changes from manufacturer to manufacturer. But duration @.050 is just that, no matter who's camshaft you go with.
Just for comparison, the Comp Cams Stage III cam for our 4.6 3Vs (max effort street cam) has duration @.050 of 237 intake and 244 exhaust.
The T&D shaft mount rockers, the crower solid roller lifters, valve covers, etc should all be coming in next week. :evillaugh:
psfracer
billy badass
Valencia, CA
Oh and I finished putting in the 9 inch rearend tonight. Everything fit perfect--I highly recommend Currie if you ever want to go with a 9-inch Ford rearend. All I have to do is finish mounting the stock brakes tomorrow.
coming together! you have a ETA on first start up yet?
