Project Kama Kaase (Ka-zee)
don_w
Dyno Numbers - Who Cares?
San Diego, CA
I think I might get the FRPP A460 block instead of the eliminator block, as the A460 block can go to 4.600 bore vs the eliminator at a max 4.500 bore.
So, what CID would you be looking at with that block?
psfracer
billy badass
Valencia, CA
My "Billy Bad Ass" fuel system came in today......
Ken3030
all that fuel system for a little 460 motor makeing 950? WTF
psfracer
billy badass
Valencia, CA
While watching the Drag Radial Vs the World event in Georgia on the internet, I finished the fuel system today. There is some unbelievable fast cars in that event.
Will run the lines forward once the cage and motor plate is done. I ran two lines from the fuel cell to the aluminum floor, and used bulkhead fittings to run to the outside of the car. One is a -8 return for fuel, one is a -8 vent with a roll over check valve.
Here is what it looks like underneath. Still need to run the return line and the -10 line to the front.
white05gt
Illinois
Looks good, nice clean install. Is the pump or lines going to be visible like the older mustangs or is it mounted high enough?
