2013DIBGT
I Hate Wheelhop
Hello,
I'm curious to hear about the process used by those who drive their car on the street, often, and also hit the track (with turns) while maintaining their suspension settings for each occasion.
Do you maintain just one suspension setting for all occasions and hope for the best on most of the major components and just play with shock adjustments on track day or do you go through a more involved routine leading up to track day where you make adjustments to things like alignment, ride height, rear control arm length (if applicable), sway bar stiffness (if applicable)...etc...etc?
If you go thru the longer list, do you do it yourself at home or do you take your car to a shop that has a machine capable of measuring Caster/Camber/Toe & Thrust Angle..etc with Lasers Beams and shit?
On a similar note, when you first installed all your stuff, did you take your car to the previously mentioned shop (with laser beams) so they could configure the car for all the ideal/perfect world measurements so that you could then record all these settings and maintain them as your baseline and return to them if needed in a repeatable fashion on your own later?
A detailed log book would seem to be a minimum requirement here in order to not get lost along the way but have you done things like make markings on your suspension components for each of the various configurations (ride height, control arms lengths..etc) so you could get back in the ball park of the "ideal configuration" for the task at hand without having to always resort to the use of plum bobs, micrometers and rulers each time?
Just thinking out loud here, but I would imagine one would want to keep ride height adjustments to a minimum since doing so alters so many other things in a domino effect.
Here is a short list that comes to mind that I believe will change with ride height adjustments. If any of these are wrong please let me know. Some of the settings would probably be a bit more difficult to get right on the floor of a garage without a lift:
Pinion Angle
Caster/Camber/Toe/Thrust Angle
Roll Center
Bump Steer
Corner weight balance (if done to begin with)
Lastly, how many folks have gone thru the effort to corner balance their car and is it difficult to maintain those settings when mucking around with all of the above?
Please post your experiences...Thanks
Pinion Angle
Roll Center
Bump Steer
