Removing valve guides
BruceH
BBB Big Bore Boss 322
So what's required to regrind the valves? Is it as simple as chucking one up in a drill with a good chuck, using some valve grinding compound or similar abrasive, and pulling it against the seat? Or would that be the shade tree/redneck way to do it?
05stroker
Never enough power guy!
Bullard Tx.
Not sure, I will leave that to the machine shop I use.
01yellerCobra
San Diego, CA
I saw them do that on Horsepower TV once. Has to be easier then using the suction cups.
Misspelling brought to you by tapatalk
TexasBlownV8
Formerly TexasBlownV6
Central Texas
We've always ground by hand, using a suction cup and a valve grind "crank" tool..has a handle on the side you turn and it oscillates the valve back and forth in the seat. Grind until you see 6-8 or so tiny grooves cut into the valve. Again, this is old-school mechanic style.
tmcolegr
It's All About the Build
Central, FL
if you're going to grind the seats I suggest using a machine similar to this or equivalent
Hand lapping afterwards is unnecessary. Only reason to perform that task is to confirm seat to valve width and location.
PNR Welding
Hammonton, NJ
The proper way is to grind either a 3 angle or 5 angle, and then lap them to the seat. Amy decent machine shop would charge 30$ - 40$ a head.
If the cylinder holds 20+ vacuum, then it will be OK and not needed.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
This.
Edit: I'm a bit behind the times but I still like lapping the valves rather than just trusting the cutter. It seems that with the right gear lapping is not necessary according to some builders.
awesome autocorrect malfunctions brought to you by tapatalk
