Road Race Suspension///
SoundGuyDave
This Space For Rent
I get it now. The cross weights are 1lb different so that is what he meant by 50/50. Not that the left vs right is 50/50. I'm still interested in finding out why cross weights are more important than actual weight locations when it comes to balance. I plan on Googling that.
It's not really the easiest to explain, even though it's a pretty easy concept... Suffice it to say that if the cross-weights aren't pretty even, the left vs. right handling balance suffers. Understeer on right turns, oversteer on left, if you follow. Yes, you want your left-side weight as equal as possible to the right-side, and the front-weight as equal as possible to the rear, but the real key is in the cross-weight, and it's something you can seriously feel when its right!
This car is an autocross car though (well it's a daily driver that gets autocrossed), so no requirement for fire bottle, cool-suit or ballast. ST has no minimum weights just a crap ton of requirements stating what can be changed (and everything else is assumed not). I've autocrossed this car with the 50 miles to E spamming the information center on the dash without any fuel starvation issues hence why I wasn't afraid to have the corner weighting done at 1/8th of a tank where last year I spent most of my time autocrossing at for fuel. I generally fill up on the way home.
The good news is that the shop didn't lead me astray! :)
Ahhh, but the devil is in the details! Google Smokey Yunick while you're at it, then put on his hat and start thinking about weight. Weight is the enemy, pure and simple. At 3441 you're actually already reasonably light for an S197 in full street trim but there are still places you can shave weight. I don't know the rule book, but you have to get creative with interpretation but stay legal to the letter. I helped a buddy build a race car, and working through the rules LINE BY LINE, we pulled as much weight out during the build as we possibly could, and came up almost 300lbs light. The scales said he was too light in the right rear, so instead of using the gucci aluminum mount for the cool suit cooler, we fabricated one out of 1/4" plate steel. This allowed us to put the weight where we wanted it, rather than having to run big lead ballast blocks in the specified location, which was less than ideal for the cross-weight. After testing, we wanted more rear-weight, so the ballast stack was reduced by an addition of a double-layer of dynamat under the entire trunk area for "interior noise control." There are a million tricks like that, but you have to start underweight to begin with. If you don't have a number to hit, but are required to have certain components in certain locations, you can still play... Need a stock-type battery? Take a scale and go shopping. I've found a certain "import" brand group 24F battery that was a full two pounds lighter than the typical Interstate replacement. Here is a place to get creative! I'm not advocating cheating, far from it, but if the rule book says "X," and you comply with it, that's hardly cheating. Just make sure you're reading what it says, and NOT what it means!
And no, your shop did NOT lead you astray, your numbers actually look killer. Like you, my cross-weights are within one lb, but I am way light in the rear compared to you! I really need to find some weight to ditch in the left-front...
@fun4me - I ran a full year + autocross with -1.7º camber and NO toe in the front but -0.16º toe out in the rear (thanks Ford! :p) and was still wearing the outside edge of the tires! Autocross is hard on tires. Still, the insides of the tires still have the nubbies on them from the molding and they look brand new compared to the outside edges. Flipped the tires on the rims, switched sides they were on and called it a day! More camber for this year!
Truth right there!
California Special: Yes, final ride heights are completely dependent on the corner-weighting, but unless something is WAYYYY out of whack, you're only going to be looking at differences in the fractions-of-an-inch range, nothing visually obvious. Also note that to properly corner-weight the car, you need to be able to take the swaybars out of the equation. Adjustable endlinks up front, and some form of adjustment in the rear. In my case, there's enough room in the bolt-holes of the rear drop-links to take the preload off. There's no point in getting the cross-weight perfect, then adding 50lbs or so of front bar preload (25lb change to both front wheels), if you follow. The way that I approach it is to figure out where you want to be in terms of gross ride-height (factoring in suspension travel, spring rates, roll centers, handling balance, etc.), then scale the car. Proper corner-weighting is absolutely an iterative process. Test first to get the rough ride-height and spring package, THEN align, then scale, then aligh, then test, then align, then scale, then align... I think you get the picture. You may be surprised at how HIGH your final ride height winds up being! CG is important, but nowhere NEAR as much as roll-center and handling balance!
fun4me
Thanks for all the replies. Do the toe numbers look ok? I got my alignment at the local used tire shop, for $30.... I just told them to use the Boss LS settings.
Whiskey11
SCCA Autoscrosser #23 STU
Thanks for the tips Dave. I have that list of about 155lbs worth of weight that is low hanging and not compromising in streetability. I will do as you suggest and go theough the rules line by line to find more weight to remove.
Detroit, MI
Thanks Dave. That's more or less what I had going on in my head. I guess I was just wondering if it were at all possible to get cross/corner weights to play well with each other while still being pretty low; say 2in. drop or so. I know it wouldn't be the best handling scenario but its mostly just a DD and i love the low look
SoundGuyDave
This Space For Rent
You can corner-weight at ANY gross ride-height level, but if you're sweating millimeters of fender clearance, you'll have to make some compromises. Figure no more than 1/8" difference on any given corner to get the car to scale right. With a 2" drop, unless you're doing some serious roll-center correction, yes, the handling will be compromised, but that is part and parcel of a dual-purpose car.
Detroit, MI
Again, thanks a bunch for answering my trivial questions. I got some reading to do before i pull the trigger on my next suspension decision haha
Norm Peterson
corner barstool sitter
RIP - You will be missed
Still not all that serious yet . . .
Koni yellows
Steeda upper strut mounts
Sam's 35mm & 22mm adjustable sta-bars
Strano/UMI adjustable endlinks
18x9.5 GT500 wheels
255/45-18 Goodyear Asymmetrics
Carbotech XP8 (track); Hawk HP+/HPS pads (street, until the ATE rotors are gone)
Centric rotors (track); ATE rotors (street)
Currie rear LCAs (Johnny joint/modified poly)
The same slightly out of spec alignment that the car originally came with
Norm
sheizasosay
Alive
Little late, but why not:
Bridgestone RE-11 275-35-18's on TSW Nurburgring 18x9.5" 43mm offset.
GT500 front control arms
Stock front sway bar
Koni Sports
Steeda Competition Springs front, Tokico 200in/lb rear springs
Steeda HD camber plates running -1.8* camber, 0 toe, stock caster
Brembo 4 piston brakes
Vorshlag dust shield for brake cooling hose mounts
3" hose running to some hacked up Allstar brake duct inlets
PFC z-rated pads for the street. No track pads yet.
ATE Super Gold/Blue
BMR UCA mount in top hole
J&M Street Extreme adj UCA
J&M Street Extreme LCAs
Techco Watts link modified for double shear center pivot and adj arms (courtesy 908SSP)
Laying around the garage: Tokico front springs (240in/lb), Bilstein HD rears, MM heim LCAs, OE front control arms with one of the bushings drained daring to be finished off with Prothane front control arm bushing (bracket included); GT500 rear sway (24mm) on the shelf.
sheizasosay
Alive
Did the fluid just drain out easily or did you need to drill a vent hole as well?
Norm
I took a knife to it and cut a slit in the bushing. I twisted the knife to open it and it drained a fair amount. I then put it on my garage floor (epoxy'd) and left it overnight. Quite a bit more drained out. Mine never "sprayed" like Vorshlag's did in their thread though. A day or so later I put it on my newly purchased vice and took a torch to the metal bushing case and heated it enough to twist the bushing case about 45 degrees. I couldn't twist/pull it off. This was more of an experimental go and not a full-fledged attempt. I could have heated longer. I was hoping to have an extra set of hands to work the case while I heated for the full-on attempt.
I wish I had a press because I believe that between the heat and the press it would be an easy one-man job. Gmitch tried a press with the bushing cold and bent two big steel plates and the bushing still didn't budge. I bet it would have came off easy with heat.
I will give it another go when I get a 2nd set of hands probably.
Whiskey11
Alrighty then... time to update:
Car/Class:
2009 Mustang GT 4.6L 3v V8
#23 or #11 in some SoloII class... STU or CAM I suppose
Suspension:
-Ground Control Coilovers - 550lbs/in front, 275lbs/in rear
-Fays2 Watts Link - Rear roll center maxed up
-Stock rear 20mm swaybar
-Strano Performance Parts 35mm front swaybar (full stiff)
-Cortex Racing Torque Arm
-Modified Stock LCA's with Poly Bushings
-Enkei PF01, 18x9 ET45
-Hankook RS3 265/40/18
-Unknown alignment - shooting for -3.0º camber, -0.10º toe out, and +7.0º caster again
Brakes:
-Bone Stock
Engine/Drivetrain:
-K&N Drop In Filter for stock air box
-Rebuilt T-Lok with Carbon Fiber Clutch Packs
-Ford Racing Finned Differential Cover
Aerodynamics:
-None
Other:
-Rusty Again rear axle
-Hopes
-Dreams
-Desire to succeed
Because I'm a Picture Whore, here are some photos from Nationals pre 550/275 springs:
And a couple for those who are confused as to what it looks like when it isn't moving:
sheizasosay
Alive
Hey guys, I have my own curiosity going here and I don't want to create another thread for it and for once I don't think this would be an official thread jack. I actually think it would fit perfect in here. Plus I'm worried if I create another thread there will be only a handful of people that collected relevant data.
On to it:
Plenty of people in here have posted up their setups. What would be a nice touch would be peak and sustained lateral G's. I know their probably wouldn't be a lot of available info, but I think it would bring a lot to this thread if you could look at someone's posted setup and see what kind of grip it produces. I think what sparked it off for me was on Maximum Motorsport's website they have their Track Pack setup: http://www.maximummotorsports.com/2005-2010-Mustang-Road-and-Track-Grip-Box-P1442.aspx.
I am not calling MM a liar, but a sustained 1.2G load on a 300 treadwear tire, I believe, is very impressive. Of course all the details one would want to know are not available to debate. Knowing the car weight, tire width and what the road surface was like (bank/camber, prepped surface) would help understand that. Or maybe I'm more impressed than I should be.
I know for my old suspension setup, I pulled 1G peak, maybe 1.01G and that was on 275 40 18 Goodyear Eagle GS-D3 tires. Those are 280 treadwear tires. I failed to datalog my new tires, which are unbelievably stickier than the Eagles. I would believe 1.2G, but suspicions aren't gonna cut it. I will be sure to log it next track day.
OP- Hope you don't mind.
Whiskey11
On to it:
On the Tokico D-Specs, Steeda Sports and -1.7º of camber on 245/45/18 Star Specs I peaked 1.28 lateral G and averaged upper 1.1's to low 1.2's. Haven't measured since really as the data wasn't showing me much and it was a PITA to setup. I used Accelerometer Pro for Android Phones on a Droid Razr. Here is a tire grip acorn for you to look at:
Not that interesting really. Who knows if this data is dirty (accelerometer error or phone sliding around). Here is the accelerometer data plotted against time:
And I think this was the course:
I'd be curious to know what the car does now with the changes, but not curious enough to endure getting the phone setup to do this. I'd rather do video which has more value to me! :)
Whiskey11
Thanks Whiskey. There are apps that do video with overlays. Harry's lap timer does it. But I hear you on setup being not as easy. 1.28g's in 245 star specs even sounds high/good. I need to get back on the track an log mine. My brain is "out of cal".
EDIT- List of apps for tracking with iphone and android.
http://www.renndays.com/en/rennblog/17-smartphone-apps-for-trackdays.html
I don't have a stable navigation mount for my phone, at least not enough to take video and data. That's part of the problem. You've seen my videos before anyway and you've seen how they can be shaky and lose focus easily. I don't think that'd help the whole data acquisition thing. A Droid Razr fits perfectly in the cup holder on the ledge between each cup holder. That is where I had the phone for the runs I collected data on.
sheizasosay
Alive
Norm
Here you go Norm....behold, the power of the dremel lol!ImageUploadedByTapatalk1394413164.303865.jpgImageUploadedByTapatalk1394413179.719868.jpgImageUploadedByTapatalk1394413196.414796.jpgImageUploadedByTapatalk1394413215.304762.jpg
Once I cut the line in the outer case it basically sprang open a little. Removed that and then I finished cutting the inner sleeve and it sprang open too. Really very easy ;suprisingly). When cutting the inner sleeve, you know you're deep enough when you smell burning rubber ;).
I'll get back to cutting the rubber off later. I'm in no rush.
Arustik
On to it:
FYI I believe MM was running a 275 or 285 square setup for the 1.2G logs.
Roadracer350
Tulsa OK
Does anyone know if Vorshlag is doing this with their red car? I would be interested on what Gs their pulling using those big 345s
