Perfect for guys looking to run 500rwhp or less on the stock block with room to upgrade in the future. This setup will support around 600rwhp depending on injectors size without a bap and is a fraction of the cost of the frpp gt500 system. Kit features a modifed GT hat with a walbro 405 pump which flows 440lph @ 13.5 volts/39psi! Also includes my fuel system wire upgrade kit which runs 10 gauge wire with relay to the fpdm to support the bigger pump. The fuel hat is is a direct swap drop in and the wire kit comes with color installation instruction for a clean and easy install. Best value fuel kit you can buy for your S197!
Full setup is $275 with free shipping in the cont us.
*Have your own fuel hat for me to work on or have a spare you want to send me? Send me the hat and the kit is $240 including return shipping to you.
*The fuel level sender resistance reading changed in 2010 so please specify wether you need an 05-09 or a 10 style sender.
*Add $25 if you would like the pprv valve deleted off the hat with this kit.
*Requires custom tuning.
