S197 Upper Control Arm Differences
BMR Tech 2
Kelly's Replacement Lackey
Tampa, FL
Dammit Dylan.
We make the absolute, not debatable, baddest S197 UCA on the planet - and you had to use the cookie cutter poly-bobo UCA for this write up?!?
SMH
Easier to show UCA lengths with fixed UCAs ;)
Happy now?
Wes06
Dammit Dylan. Demotion for you!!!
^^ohhhhhhh
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Kinda choked that I didn't know that if you planned on replacing both parts, you could use the 2011+ parts.
Oh well, I'll keep what I've got.
Is the adjustable portion on the 11+ UCA's long enough, so you can get the extra 1" of length required.... when using a 11+ adj UC + mating 11+ mount...... on a 05-10 car ??
Wes06
The entire point is to start the 11+ uca's are an inch longer than the previous ones. Before threaded adjustments.
BMR Tech 2
Tampa, FL
I'm not really sure what you're asking here... There is no need to adjust the 11-14 UCA longer on the earlier cars. It's just a direct swap when using both the 11-14 mount and arm. If you lengthened the arm an additional inch, your pinion angle would be waaay off.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Dammit Dylan.
SMH
BMR'S UCA is basically nuclear-hardened.[emoji106]
Sent from my Samsung Galaxy Note 4 using Tapatalk
Point well taken.... I was having a senior moment... semi brain dead.
The bushing assy on the 11+ UCA is HUGE vs the bushing on the 05-10 version...like apples + oranges. See 4th pix in posting #1..and also the pix on posting #21.
slackinoff
East Texas
Great write up. I had no idea you could do that.
Is there a benefit to installing an 11+ arm and mount on an 05-10 car? Other than looking super beefy and awesome.
Looking at those tolerances on the OEM mount, I assume most of the benefit is just getting rid of that junk whether you go 05-10 or 11+...
R.M.
Antti
Finland, Europe
At the moment there isn't BMR UCA bracket available for 2005 Mustang that can mount 11+ longer UCA? Why?
Antti
Finland, Europe
Racer47 what i see in your picture is the bracket that uses short length 05-10 UCA instead of longer 11+ version.
Racer47
Doesn't have much to say
SE Wis
That bracket is the correct one for the longer link. It's on my car right now. Just call bmr if you don't understand.
