Sky Render
Stig's Retarded Cousin
Part 7: BMR Rear Suspension
I would like to at this point have a discussion of panhard bars. The main disadvantage that I see attributed to panhard bars on this forum is the "unsettled" feeling of the rear end when going around corners, especially during fast transitions. After a steering input, it seems to take a finite (albeit brief) amount of time for the rear end to "settle" and correctly respond to the input.
Now, Newton's First Law states that an object in motion will stay in motion until acted upon by an outside force. Consider that you are driving your S197 in a straight line. You then enter a sweeper and turn the steering wheel. The front of the car immediately follows the wheels, because they are turned. But how is the rear axle brought "in line" to follow the front wheels?
Mainly, it is through the panhard bar. That bar must either push or pull the axle to make it go around a corner. But before the force of the chassis can completely be transmitted through the panhard bar, it must compress the bushings at either end. And recall also that the rear axle is a heavy sonuvagun, weighing at least a couple hundred pounds. So that bushing deflection and compression is HUGE. Those bushings must compress before the axle "feels" the forces transmitted through the panhard bar.
My point to all this rambling is that the "unsettled" feeling of the rear axle during transitions has all but disappeared by replacing just one of those bushings with a spherical bearing. Thoughts?
Just gotta search for it (having seen the posts around here to give a clue).
