Slipping in 2nd gear only?
Ricosbullitt
Not sure if anyone has experienced this before, but im not sure if its my clutch or not because this is odd to me. So I only have 23k miles on my bullitt and dont really beat on the car at all. Recently, the car has been slipping in 2nd gear only. Weird as hell because it will not slip in the higher gears at all. I have tried a low rpm 4th gear and 5th gear pull and the clutch feels fine in those gears. It has only done it few times and when it has, it was when I was trying to run through the gears quickly (little more than half throttle). It will pull fine in 1st and then as soon as I hit 2nd, it slips for a bit? Not sure if should take it in under warranty or not, being that it might be the clutch. Im thinking that maybe my slave or something else is fubard? I appreciate any thoughts or opinions guys.
