Slp line lock - Advice
ayabrego
Sprayed yaaa
Corpus Christi, Texas
I am on the first step it says to drain the brake fluid from the master cylinder by either suck it from the top or drain from rear brakes. Can I get by just draining the front brakes? Any advice is appreciated. I have never done anything with brakes before so be kind.
thanks.
Disconnected
06 Mustang GT Convertible
I didn't drain any brake fluid. I let it drip, only an oz. at most came out. I am still in process. I need to bleed the brake lines and find a place to mount the switch.
ayabrego
Sprayed yaaa
Oh so your installing your line lock right now? Did your drain from the front calipers? Also i plan on putting my switch next to where you turn on your fogs in the blank gap. I just took off both tires but i dont want to start draining from wrong area. How are you doing it.
where did you let it drip from
Dex
I'm Dexolishous
Utah
I didnt drain it completely but you will need to buy some more brake fluid.
After installing it you'll need to push the air out of the lines. You pump the brakes until you get pressure and then while your foot is on the pedal you have someone open up the bleeder valve and let the air out. Once you get straight fluid move to the next caliper
5.SLOW
missouri
i just did mine to and i bought a plug to plug off the master cyclinder. and then bleed the front brakes.
Disconnected
I am doing Hawk HPS pads, ATE Yellow and Russell ss lines at the same time. So I have to bleed all four brakes. I am thinking about using the fog light switch. I removed the MC to ABS line and let her drip.
ayabrego
Sprayed yaaa
I head a question guys, I am having a hard time understanding these instructions. How do put together the line lock? Also what does NPT stand for?
Hawgman
THE fucking bad guy
NTP - National Tapered Pipe
Hawgman
THE fucking bad guy
Damn.. beat me to it
Don't over complicate installing this system. The hardest part of the whole job is deciding on where you want to put the switch. You don't need to drain the brake reservoir. Just remove the one line it tells you to remove, put the 2 piece line back in it's place with the solenoid in the middle. Run a hot wire in to the cabin to one side of a switch, run the other side of the switch to one pole on the solenoid, ground the other pole of the solenoid. Bleed the front brakes. It really is that simple.
ayabrego
Sprayed yaaa
thanks for the input yah I figured it out are there any holes in the firewall that allows me to run the switch? Also the tubes connecting to the solenoid should they be very tight? or should they be able to swivel?
Thanks for all the help mounting this solenoid is going to be a PITA!
JoshK
Modder AKA Fuel
Nebraska
There is a rubber grommet that has a spot you can sut to run the wire through right below the brake pedal irrc. If you take the plastic inner fender out on the drivers side you can see it very clearly.
Disconnected
Is the switch just grounding the solenoid? Since the fog lamps were deleted, could the fog switch be used? Or is that a positive switch and we need a negative one?
ayabrego
Sprayed yaaa
I actually just got done hooking up the tubes and the solenoid. Omg that was annoying so many tight areas not really hard just annoying. I am really not sure on how to hook up this switch either... Can anyone chime in?
ayabrego
Sprayed yaaa
I am confused can anyone help? The I just routed the harness with the fuse from the fuse box to the solenoid I connected it to the fuse box and the female spade to the male solenoid. in the instructions he talks about how their are two female spades is he talking about the other wire harness with the switch?
instructions: step 14. He talks about BOTH wires. But what wires. Please help.
http://lib.store.yahoo.net/lib/mustangtuning/slp-brakecontrol-package-0506gt-install.pdf
is he talking about the female spade on the switch harness.
BoostedGT480
Slow 3v
Montgomery, AL
the kit should have came with a wiring harness which have the female connectors on them...The solenoid has 2 male connectors attached to it..Just hook them together and it doesnt matter which one goes where
ayabrego
Sprayed yaaa
Yah i got it all done the solenoid works I believe. It clicks when i flip the switch. I bought a different switch that some other people used for there line lock its this one.
post 6
http://www.s197forum.com/forum/showthread.php?t=56337&highlight=line+lock+switch
I have the exact same switch. There are three female spade on the back I have wired to ground and the other to the solenoid what do I do with the third prong?
I am saving the rest for tomorrow. I just need to refill the brake fluid and bleed the lines manualy.
JimC
It says on the back of my switch - one goes to ground, one to power, and the third goes to the solenoid. Is there a label on the back of the switch? I had it on the switch and on the box it came in.
Hawgman
THE fucking bad guy
If it is this hard for you to figure out.... sell the kit
