chad05gt
gonna just add warm 0-20 benz stuff on the stove and add 2 oz to each breather every morning... drive car up on ramps every night and drain 4oz.
Do they offer an upgraded follower? The stock ones look like cheap cast metal.
Pics?????
They're actually cheap stamped steel. Either way, not the greatest.Do they offer an upgraded follower? The stock ones look like cheap cast metal.
I mean do we have an aftermarket alternative?
Jesel lol
i STUDIED THE FOLLOWER VERY CLOSELY YESTERDAY. lOOKS LIKE THE BEARING IN THE ROLLER FAILED. mOST LIKELY AN OIL ISSUE. i BAUGHT SOME 10w30 FORD SYNTHETIC BLEND OIL LAST NIGHT. gONNA LOOK AT THE HOUSING AS WELL. ALSO GOING TO CHANGE THE VALVE SEALS ON #7 & #8 CYLINDER
Exactly, I don't see how the cam journals on the heads can't be wiped. Also wondering what the oil pump pickup tube screen looks like, I'm thinking it might be plugged with shavings.20W50 IS too thick. Sure it may "work" for some, but for how long? This should be a fine example of why it doesn't work.
Pull the valve covers off and start a cold engine up with 20w50 and see how long it takes for the oil to get distributed throughout the valvetrain on a modular. You'd be surprised and shown that you're starving your heads of oil on every cold startup.
Even with the VCT deleted completely from the heads ?20W50 IS too thick. Sure it may "work" for some, but for how long? This should be a fine example of why it doesn't work.
