00blkvert
Hey guys I've been trying to find this vibration in my steering wheel. This started a couple months ago I just haven't driven it much since but the steering wheel shakes at speeds over 60mph. It doesn't happen all the time this why I think it may be a wear item possibly. When I'm in turns it doesn't vibrate at all but when it comes out it'll start shaking again. It shakes more often then not.
I have a BMR K member, AArms and so on, koni yellows, ground control conversion springs and GT500 mounts. It has been on the alignment rack twice and when I took it back the 2nd time and the passenger side toe was out some even after it being in spec the first time. I have also had the front tires rebalanced twice.
I remember when I installed the k member passenger side inner tie rod seemed to shift or I pulled it a little when I put the tie rod back into the spindle. If you need more info ask away. My next step is a true set of CC plates and getting rid of the GT500 mounts and a passenger inner tie rod unless you guys have suggestions.
