stock e fan motor "high" side burned out.
mr. anderson
Moore, OK
Just a odd thing that happened to me, I had the high side of the fans burn out. very odd. the car overheated in traffic. I drove it home after it cooled off. I checked the fuses and relays. all good. the fan spun freely but did have the " the magic has left electronic part" smell to it. also after i pulled the fan assembly, I ran it on just 12 volts direct to the motor, motor spun freely, but the high side didn't work. ordered a new fan assembly. installed and it works great. just seems very odd that the high side of the fan burnt out. I suspect it was the thermistor section that failed that draws the high side, never had that happen.
Steve@Tasca
You sure it wasn't the resistor that failed? Oddly the complete fan assembly with resistor is cheaper than the resistor alone so replacing the assembly makes more sense.
-Steve
mr. anderson
Moore, OK
yeah, I wouldn't think so either, but the fan section definitely had a burnt electronics smell to it. either way for a 100 bucks, i say meh, replace it all. the red wire from the thermistor section to the fan also looked like it got very hot as well.
Steve@Tasca
When you say "thermistor" are you referring to the fan resistor?
mr. anderson
Moore, OK
yup, I also pulled those little metal clips off the fan shroud assembly before i chucked it, those are usually outrageously priced.
